Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 12-22-2021, 02:45 PM
blogbuchstabe blogbuchstabe is offline
Default Re: Protools first won’t load after downloading plugins
Hi !
I'm jumping in here as I'm having the same problem - my PTF gets stuck while "scanning plugins" on first launch ...
I've downloaded and installed PTF version 2021.6.0 today on MacOS 12.0.1 on my Intel MBP (16 Zoll, 2019).
Reading this thread I wanted to show you my list of plugins to identify any showstoppers ... just to find out that I don't have any Library/Application Support/Avid/Audio/Plugins folder !
I only have a Library/Application Support/Avid/Pro Tools
(containing a "Cache" and a "Cookies" folder - no plugins folder !
I have created the Library/Application Support/Avid/Audio/Plugins folder manually then - but PTF still hangs on launch :-(
Any ideas ?
Thanks
Tom
Old 12-22-2021, 03:11 PM
JFreak's Avatar
JFreak JFreak is offline
Hi, welcome to the community.
PT|first generally speaking does not support 3rd party plugins. Only the ones that come with the install itself, the ones you buy from Avid Marketplace, and some special arrangements with 3rd party hardware vendors such as focurite.
Janne
Old 12-23-2021, 03:16 AM
Thanks Janne !
Wasn't aware of that ...
But as I don't even have a plugins folder (or now a manually created empty folder) I'm not quite sure to solve my problem with PT|first hanging on launch while "Scanning plugins" ...
Any ideas ?
Thanks
Tom
Old 12-23-2021, 03:17 AM
JFreak's Avatar
Compatibility info here.
Janne
Old 12-23-2021, 04:24 AM
my system meets the minimum requirements by far...
2.3 GHz 8-core Intel i9 with 64GB RAM ...
  #16
Old 12-23-2021, 04:30 AM
Is there maybe the possibility to skip the process of plugin scanning ?
For example by pressing a key during launch ?
  #17
Old 12-23-2021, 05:14 AM
JFreak's Avatar
It has last been supported on Catalina and you are running two generations newer OS, that is likely your problem.
Janne
Help Downloading TAL Plugins ethandla macOS 7 11-05-2016 04:58 AM
about downloading a VST plugins for protools 9 / Windows 7 stiphane Pro Tools 9 6 12-08-2013 11:48 AM
Pro Tools 10 not load plugins,freezing load.HELP javierboz Windows 2 11-08-2012 04:25 AM
Protools Freezing on load up/ plugins. Apolloape macOS 5 10-24-2012 05:11 AM
downloading plugins mandyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2007 01:02 PM
