#21
Hello Eddie, thank you for your reply. They are custom key strokes assigned to buttons on S1 and the dock. I can see saved key strokes on the setting ,but it won't do anything when I push the button.
#22
![]() Quote:
Remove EuControl and MC_Client (highlight and then hit the minus button below the list) Then hit the plus button and re-add both EuControl and MC_Client (they are both in the Applications folder) and make sure they are switched on. Reboot computer. Check again with your keys. Known issue with macOS. It shows as if they are authourized to Accessibility but they aren't. Deleting and re-adding fixes that.
Pro Tools Ult 2024.10.2, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.2 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 11-16-2023 at 10:32 AM. |
#23
See BScouts reply above
#24
Thank you guys! Yes above method solved the problem. Cheers!
#25
tried everything discussed here but still no results… Also using Eucon 2023.11 with ProTools 2023.9… Unfortunately with Sonoma 14… Anyone think that's the big problem?
#26
![]() Quote:
If you're still having issues, let us know what they are. We have this all working in our test machine running Sonoma |
#27
Hi Iain
Seems like I'm experiencing permission problems. When I start Eucon, I see the fully lit control app on my Dock tablet for just a second, and then it goes grey. This suggests that the system is blocking Eucon. I removed and re-enabled Eucon, MC_Client and PT in the security settings but to no avail...also did a full de- and re-install of PT 2023.9. Running Eucon 2023.11 with Sonoma. Thanks for any tips - this is getting quite nerve-racking... in the past, Eucon has magically started working after 2-3 re-installs... |
#28
![]() Quote:
What's the status of EUCON in PT (Edit Window>EUCON widget; should be green) Do you have anything in the Application list in EuControl Settings? |
#29
I'm getting constant disconnects again after going to EC23.11 and PT23.9 and current AVID control app (on FireHD10). It was all working fine before the install.
Unfortunately the "hot fix" sticky post has disappeared from this channel. Could you please re-stick Eddie? I want to try and re-apply the fix again and see if that helps. I can't remember what the code was. Thanks! Frank
PTHDnPCIe 2024.10.2 (OSX14.7.4), Eucon 25.3, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#30
Ok, never mind. Found it but it turns out the fix was already in the .plist.
hm..
EUCON 2023.6 Released | EddieJones | Avid S1, S3, Dock and Control App | 21 | 07-27-2024 05:51 PM |
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta | theodd | Avid S1, S3, Dock and Control App | 14 | 10-19-2023 07:23 PM |
EUCON 2023.6 Released | EddieJones | Avid S4/S6 | 3 | 09-14-2023 02:26 PM |
Eucon 2023.6 Crashes often when using PT 2023.3 | Selle Sellink | Pro Tools | 3 | 08-06-2023 02:29 AM |
EUCON 2023.6 Avid Control released early. Download link for EuControl | EddieJones | Avid S1, S3, Dock and Control App | 62 | 07-28-2023 04:22 PM |
