Old 11-10-2023, 10:32 AM
EddieJones's Avatar
Default Re: EUCON 2023.11.0 Released
No the Surfaces page in EuControl
Old 11-10-2023, 10:58 AM
philcollis philcollis is offline
I have it working now. I went to Privacy & Security in Settings, then Accessibility, and turned EuControl off then back on again which I had tried before, but this time I did that to Pro Tools as well, and now the iPad will link. Don't know why - trial and error approach...
Mac Studio M1, OS 13.2.1. 64 GB ram. Focusrite Scarlett 18i20 3rd Gen USB interface. Pro Tools Studio 2023.9.
Old 11-10-2023, 11:13 AM
oranges oranges is offline
Originally Posted by EddieJones View Post
If you hold control and then pull up the menu from the EuControl Icon theres a item that says disable crash reporting. Try that.
clicking the 'disable crash reporting' doesn't seem to do anything - even after restarting. The two crashpad_handler processes still run.
I tried rolling back but of course there is a version mismatch between ipad app and EUcontrol so it won't connect
anything else I can try ?
Old 11-10-2023, 11:28 AM
Thanks for your replies, was a worrying time, all good now. Maybe someone else will have the same problem, so this could be helpful...
Old 11-10-2023, 06:53 PM
audiogamble audiogamble is offline
So far it works great over here. Thank you for this update.
Old 11-11-2023, 10:45 AM
EddieJones's Avatar
Can you message me a link to the logs. You can get them by right clicking on the EuControl notification icon once its running
Old 11-12-2023, 12:59 AM
cablenaute's Avatar
cablenaute cablenaute is offline
Working perfectly here, thanks for the update!!!
MacPro7,1_12Core • ProToolsUltimate • DolbyAtmosRenderer • Avid_S1 • MetricHalo_2882_3d • UnityAudio_TheRockMKII
Old 11-12-2023, 02:22 AM
BigBadBill BigBadBill is offline
Working fine here!
Old 11-15-2023, 06:59 PM
Babylonians Babylonians is offline
OS 13.6 Ventura, Intel iMac, after installed Eucon 2023.11, all custom soft Keys are not working. I appreciate the help.
Thanks
Old 11-15-2023, 08:25 PM
EddieJones's Avatar
Thanks
Can you be more specific. Is this keyboard short cuts or EUCON Commands ? Or is this the whole Appset you built not loading?
EUCON 2023.6 Released EddieJones Avid S1, S3, Dock and Control App 21 07-27-2024 05:51 PM
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta theodd Avid S1, S3, Dock and Control App 14 10-19-2023 07:23 PM
EUCON 2023.6 Released EddieJones Avid S4/S6 3 09-14-2023 02:26 PM
Eucon 2023.6 Crashes often when using PT 2023.3 Selle Sellink Pro Tools 3 08-06-2023 02:29 AM
EUCON 2023.6 Avid Control released early. Download link for EuControl EddieJones Avid S1, S3, Dock and Control App 62 07-28-2023 04:22 PM
