Old 06-25-2021, 11:37 AM
Marsdy Marsdy is offline
Default Re: 2021.6 Color Palette is way too tall now...
Originally Posted by barden View Post
Agreed. It seems like a silly thing to complain about but I keep the colour palette open in the tool bar of my edit window and appreciated that it used to tuck in that space almost perfectly. With "The Chin" it now hangs into the rulers. I would put the UI customization in the Setup menu or make it a window openable through the Window menu.
Just my $0.02.
~Barden
Barden it’s not silly at all! I always thought there should be an optional integrated colour palette built into the toolbar because there’s plenty of room for it on most displays.
Can’t help thinking that the UI customisations should have been a separate window or even a new pane in preferences.
That said, the ability to customise is very welcome here.
Dave Marsden
UK
Old 06-25-2021, 01:12 PM
Tweakhead Tweakhead is offline
and another irritating thing is that Window Configs does not remember the status of whether the UI Customization arrow is open or collapsed.
I tried making a config that placed it expanded and centered on my screen, but that doesn't help when the open/closed status is not remembered.
Also, when I set it to my saved UI Config, upon reloading the session the Preset says "factory default" even though it actually displays my settings.
Also, when clicking any one of the 5 presets, it still says "factory default", even though I saved one of my presets in each slot, and they actually take effect.
Grayscale please. Custom Colors please. PLEASE.
Having said all that, this addition is still appreciated, believe it or not !
Old 06-25-2021, 03:25 PM
Micks_Mix Micks_Mix is offline
Encountered the same problem, but there is already a solution:
https://www.pro-tools-expert.com/hom...-we-have-a-fix
Hope this helps!
Pro Tools|HDX Ultimate, 192 HD I/O, 192 HD Digital I/O, Focusrite OctoPre, Pro Tools 2021.3, Mac Pro 5.1, 24 GB RAM, Mojave
Old 06-25-2021, 08:18 PM
thanks, but that's got nothing to do with what we're talking about in this thread.
it's another issue altogether.
everyone : "it's another issue !"
Old 06-25-2021, 11:07 PM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Maybe the reason that many choose to keep the Color Palette open is that there is no built-in Key Command in Pro Tools to show/hide this Inspector.
I assigned a macOS Key Command to toggle that Color Palette Inspector, problem solved. This way I don't care about the extra chin. I even wished that I could resize the window to have all tabs open and visible.
BTW, nice addition to have the switch for the Dark Mode now on the Color Palette Inspector. Not that I will switch to Dark (I'm on the "I can't stand Dark Mode" team)
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 06-26-2021, 06:59 AM
seanmccoy seanmccoy is offline
Originally Posted by EdgarRothermich View Post
Maybe the reason that many choose to keep the Color Palette open is that there is no built-in Key Command in Pro Tools to show/hide this Inspector.[/I])
That's been a major head-scratcher for me ever since I moved to Pro Tools. I'm surprised it isn't complained about more often.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Bug in color palette OFS Pro Tools 2020 8 03-11-2021 01:39 PM
Color Palette gone... Possible bug? lapieuvre Pro Tools 9 0 07-15-2014 01:28 PM
PT 8 color palette problem bongo_x Pro Tools TDM Systems (Mac) 4 07-25-2010 10:36 AM
Color Palette question RichrdC Pro Tools M-Powered (Win) 6 04-23-2009 09:21 PM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
