PTMP Uneven Volume Issue
I have a Firewire 1814 that I have been using for a couple of years on my G5 without issue. A few months ago, I purchased a MacBook Pro and installed my FW1814 + PTMP. Everything seemed to install correctly and work fine.
However after recording several times I noticed an issue of uneven volume levels on a stereo track. The left side is much louder than the right side. At first I went through all of my HW (cables, headphones, etc.) and eliminated them as being the source of my issues. I then went through my entire config inluding volume, panning, 1814 Control Panel, etc. After that I went through the process of re-installing my drivers and even PTMP. Before calling M-audio support I even upgraded to 7.3 thinking it could solve my problem. What I did find out after countless hours of troubleshooting is that the signal is perfectly even when I monitor the HW input via the 1814's control panel. It's only when the signal is routed through the Software that the issue occurs. The issue is also present once a recorded track is played back. After spending hours on the line with a very helpful M-Audio tech we were both out of ideas. We blew away the I/O options in PTMP, we re-installed, we went through every step I had plus some. He recommended I call Digidesign and here I am. Any help would be greatly appreciated. I am at the point now I will just purchase an 002 however I do not want to pay for PT7.3 again... Here is my info: MacBook Pro 17" (Intel Core Duo) OSX 10.8 M-Audio FW-1814 Latest Drivers Glyph GT Series FW HD |
Uneven Left/Right Output Volume | fresh_meat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-01-2012 06:50 AM |
Project Mix Output Sound Issue with PTMP 8.0.5 | RichrdC | Pro Tools M-Powered (Win) | 1 | 07-16-2012 09:00 PM |
PTMP 7.3 playback issue | geminijatt | Pro Tools M-Powered (Win) | 0 | 11-27-2007 10:22 AM |
Uneven Volume on Monitor Outs | dmm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-30-2006 03:35 PM |
Uneven panning on harsh volume edits causing probs | funkyghoul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-21-2006 10:35 PM |
