Old 05-02-2022, 10:59 AM
Howardk Howardk is offline
Default 2022.4 best macOS on Mac Pro 2013
I have been running Pro Tools Ultimate 2021.12 on macOS Mojave and it has been reasonably solid on a Mac Pro 2013 10 core. I have a secondary system for testing that is identical and would like to start testing 2022.4. I tend to like to move as far forward as safe when I do upgrade, so it might be a good time to migrate to Big Sur or Monterey. I was going to do a Carbon Copy from one system to the other in Target Disk mode, upgrade macOS and then upgrade Pro Tools on the Target/Test system (hoping to avoid starting from a blank drive because it takes days to get all the plugins and sample libraries working again, with lots of heading scratching).
I would appreciate insights into which macOS is best at this time, as well as any other suggestions.
Thanks…
...for system configuration info see my profile
(Click on member name)
Old 05-02-2022, 11:18 AM
Eric Lambert's Avatar
Default Re: 2022.4 best macOS on Mac Pro 2013
Monterey has felt the best so far.
Old 05-02-2022, 02:54 PM
off the wall's Avatar
off the wall off the wall is offline
Thanks…
Big Sur or Monterey at this point.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.8.0, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.6.4
Pro Tools Ultimate 2022.12 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 05-02-2022, 07:54 PM
climber climber is offline
installed on Big Sur. seems OK so far...
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
OS X Big Sur, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio , PT2022.12, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 05-03-2022, 01:21 AM
alexthemusicbloke alexthemusicbloke is offline
I’m on a 6-core trashcan with 64gb of RAM.
Although PT2022 isn’t officially supported on Mojave, Avid say there’s no reason why it shouldn’t work.
I found there to be a significant drop in available CPU resources when I’ve tried upgrading to newer OSes on a secondary boot, so have stayed at Mojave with zero stability issues.
I’m using the rig a solid 8 hours or so every day with large numbers of plugins.
Old 05-03-2022, 01:47 PM
That’s unfortunate news. With Mojave unsupported, and moving to a newer OS being a performance step backward in CPU Usage/efficiency, it is a problem… especially when using VIs… Argh!
Old 05-03-2022, 04:07 PM
Avid does not say it's unsupported but they will no longer be testing on Mojave. That's actually a step they normally don't take and would usually have just dropped a four year old OS. I believe they realize that a sizable portion of the pro studio world is still running cheese graters.
Mac:
Intel® Mac with macOS 10.14.6, 10.15.7, 11.6, 12.3 (PT 2021.12 and later with 2022.2 Plugins)
(please find version specific qualifications in the macOS Compatibility Grid below)
Eucon 2022.4 Cheesehead Avid S1, S3, Dock and Control App 9 04-28-2022 08:54 AM
HD Hardware (HDX/HD Native) not detected by macOS (macOS 11 Big Sur newstrings Pro Tools HDX & HD Native Systems (Mac) 6 01-15-2022 11:48 PM
Chat Transcript | Avid PT 11 Webinar at NAB 2013 | 04/09/2013 Meads Pro Tools 11 13 04-29-2013 10:29 AM
Avalon 2022? Burrito_Flagship Pro Tools TDM Systems (Mac) 0 08-26-2000 03:01 AM
