Alt/Opt+Drag plug-in to a new track enables all Automation Parameters
Try this:
-Set PT to "plugin controls default to auto-enabled" -Insert a plugin and remove a few parameters that you don't want to be automated. -Alt-drag the plugin to another track -Note that PT has re-activated ALL parameters IMO PT should keep the settings and ignore the prefs setting when I copy a plugin-instance. Personally I consider this a bug because I don#t want to dive into the prefs every time I want to copy a plugin-instance. I usually have the prefs set to on. http://protools.ideascale.com/a/dtd/...ug/106097-3779
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Bug:
sorry, forgot to enter the subject line before sending. Admins, feel free to adjust it as I am not allowed to edit it.
Frank.
Re: Bug:
Actually, this issue drives me up the wall, because most of the time when I'm going to copy a plug-in over its after I've made a new track.
For example, if I run out of space in a particular group that I've made, I will add a new track and then copy a few or all of the plug-ins over. And then, exactly like Frank said, I have to dive in to all of those new plug-ins and deactivate the automation parameters. Its a real pain when all I want to do is add a quick sound effect or something to group. |
Re: Alt/Opt+Drag plug-in to a new track enables all Automation Parameters
Why are you deactivating parameters? Curious as my workflow has me never doing this. Is it just for the visual aspect of the pulldown menu being cleaner?
I never automate the master bypass because I want to be able to bypass it for quick comparisons without writing automation.
Same here: Master Bypass and with MDW there are a couple of completely irrelevant automation features as "graph scale" and "Band 1...5 Solo".
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
Ahh, makes sense.
I guess having the D Command in front of me, I just toggle in and out of Auto Modes and use Preview a lot. Good idea though if you're not using a control surface. |
Even then. It would be great to have some customizable plugin auto preferences. Master Bypass isolate being a prime candidate...
Can you please send yourself over fiber to go spam some other forum? Darryl Ramm |
I use it for master bypass sometimes, but I also use to clean stuff up a lot of the time. Like in Channel strip there is two steps to get the dynamics to work, so I just turn off automation for the EQ and DYN buttons (and set them to be always on). Then I only use the bypass for each respective module to turn it on and off.
The only work-around I've found is to entirely disable the master-bypass lane. Ultimately I still think the original posting is a bug. The function copies the plugin. And in my world a copy should be identical to it's original and not something else. Frank.
Selecting a track record enables it | e_man | macOS | 24 | 10-14-2015 11:01 AM |
Anyway to copy plug in automation of a selection from track to track? | emilano | Pro Tools 10 | 5 | 04-09-2012 09:28 AM |
Plug-in automation parameters windows are empty!? | innerbooty | Pro Tools TDM Systems (Mac) | 0 | 09-23-2009 12:36 PM |
Plug-in "enable all" automation parameters | reichman | Post - Surround - Video | 14 | 07-23-2007 07:37 AM |
Plug In automation parameters not present | wcampbelliii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-12-2007 07:16 AM |
