Just had a quote....
Just been quoted on a custom built pc spec as follows:
Intel core i5 - 2400 3.10 GHz processor Gigabyte SK1155 H67MA MATX DDR3 USB2 Mainboard Gigabyte MicroATX Case 430W PSU 4GB 1333MHz DDR3 RAM 1TB SATA 32MB 7200RPM Hard Disk Drive 22x Dual Layer DVD+RW & RAM SATA Drive Windows 7 Home Premium SP1 64 Bit £579.00 Is this a good deal and is there anything I should that may be an issue? Comments will be much appreciated |
Re: Just had a quote....
What are you using for a second dedicated hard drive?
What are you using for a video card? What interface are you using?
You have DDR3 which, with only 4 gb, will run at DDR2, you need the RAM in threes to get the DDR3 speed, so 6 gb would be better. And, IIRC, the CPU has integrated graphics, which can be problematical for Pro Tools. And it's only an i5 and an i7 would be better. As Tom mentioned, you also need a separate physical hard drive for your sessions.
First page of the i7 thread has the parts and configurations for a stable, powerful Pro Tools computer. Spend a little more money and a little more research time now and less time on computer problems later. Cheers,
The X58 Chipset is proving to be reliable as well. Not sure what Chipset that MB has.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
A 430 PSU might be a little weak for what your going to need, especially if you decide to add another HDD or 2 (other than the 2 needed) for VI's, etc...... Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 | |
Quote to do sound editing | deardaddy | Post - Surround - Video | 21 | 12-11-2013 02:42 PM |
Quote Notifications | ianbee | macOS | 1 | 09-21-2013 05:01 AM |
Help with quote for music mix | SZE | Post - Surround - Video | 6 | 11-20-2009 08:15 AM |
How to quote | defretman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 07-26-2003 12:32 AM |
shopping around for the best quote..... | Jules | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-04-2000 12:39 AM |
