#21
Re: Profire 2626 DSP Mixer buffer is locked on 64 Bits
#22
To dig in any deeper we're going to need more info - can you post your Sandra report? |
#23
#24
Running PTMP 8.0.3 on Vista 32-bit with an Audiophile 192. I have performed all of the Windows Vista optimizations referenced in General Troubleshooting, tried deleting databases and preferences, and disabling c1e in system bios. Additional hardware described in Sandra report: SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : Steve-PC User : Steve Processor Model : Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz Speed : 2.13GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5B-Deluxe BIOS : AMI 0711 09/29/2006 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P5B Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module : Corsair CM2X1024-6400 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-22-6-3) Video System Video Adapter : NVIDIA GeForce GT 220 (32 SM4.1 1.36GHz, 1GB DDR2, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce GT 220 (48SP 6C 1.36GHz, 1GB) Adapter : NVIDIA GeForce GT 220 (48SP 6C 1.36GHz, 1GB) Adapter : NVIDIA GeForce GT 220 (32SP 1.36GHz, 985.8MB) Storage Devices Seagate ST3808110AS (80GB, SATA150, 3.5", NCQ, 8MB Cache) : 75GB (C:) Seagate ST3320620AS (320GB, SATA150, 3.5", NCQ, 16MB Cache) : 298GB (D:) TSSTcorpCD/DVDW SH-S162L (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 75GB (NTFS) @ Seagate ST3808110AS (80GB, SATA150, 3.5", NCQ, 8MB Cache) Audio Drive (D:) : 298GB (NTFS) @ Seagate ST3320620AS (320GB, SATA150, 3.5", NCQ, 16MB Cache) Optical Drive (E:) : N/A @ TSSTcorpCD/DVDW SH-S162L (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS P5B LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : 6510 High Definition Audio Controller Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Codec : nVidia 000Ah Audio Device : VIA M-Audio Delta AP192 Serial Port(s) : 1 Disk Controller : ASUS 82801H (ICH8) 4 port SATA Controller Disk Controller : ASUS 82801H (ICH8) 2 port SATA Controller Disk Controller : ASUS P5B [JMB363] USB Controller 1 : ASUS P5B USB Controller 2 : ASUS P5B USB Controller 3 : ASUS P5B USB Controller 4 : ASUS 2833h USB Controller 5 : ASUS P5B FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Generic Marvell Yukon Chipset based Ethernet Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2) Platform Compliance : x86 |
#25
Correct, Buffer Lock Solved
As stated earlier I'm about 90% sure that Deleting the Prefs (as I should have seen in the trouble shooting folder) was what fixed it. It went to 64 upon the original load but now does reflect whatever changes that you make in the playback engine menu within PT8. The root cause of my playback problem was a bandwidth issue with my built in Firewire port. Disconnecting my External Drive and recording to the hard drive eliminated my buffer issue. I installed an additional 1TB Internal Drive and plan to install an upgraded PCI Firewire port. I apologize for my lack of info provided and I have taken the time now to read all the trouble shooting threads and will try to write more descriptive posts in the future. I do appreciate all the people that took the time to try to help with my issues and I'll do better in the future.
Joshua Hodge www.troytracks.com Pro Tools M-Powered 8.03 (2) Custom PCs w/Gigabyte Mother Board Windows XP Service Pack 3 & Windows 7 i5 Processor w/4GB DDR3 RAM Western Digital 150G HD 10K RPM Sea Gate 1.5TB HD 7200 RPM Sea Gate 1TB HD 7200.12 RPM Glyph 1TB External Drive 7200 RPM M-Audio ProFire 26/26 Focusrite Pro 40 (Linked via Dig I/O) Mackie Onyx 1640i M-Audio Oxygen 61 Roland V-Drums TD9 |
#26
SOLVED.
For me, the culprit was the "minimize additional i/o latency" option in the Playback Engine dialog. It is selectable only if the "ignore errors on playback/record" option is also selected. In hindsight, that's probably not a PT bug. It's probably doing exactly what it's supposed to. Honestly, I don't remember that option having been set before so I'm unsure whether I accidentally enabled it at some point or whether it was something I enabled while troubleshooting after I started noticing the problem. Either way, it's fixed now and everything is back to normal. |
#27
Ok, good to know you found the culprit! Sometimes it's the simple things - there are a lot of assumptions made that at time because of the myriad of options available. We typically assume the Playback Engine settings have been tried already but, in the future, we'll verify that in cases like these.
Issues with H/W buffer size, using Profire 2626 and PT10 HELP! | DavidNichols | Pro Tools 10 | 3 | 01-02-2012 11:50 AM |
Profire 2626 and DSP-Mixer | Beerweasle | Pro Tools 9 | 10 | 01-19-2011 10:40 PM |
Help. Profire 2626 H/W buffer size no lower then 128? | Venture Studios | Pro Tools 9 | 12 | 12-23-2010 09:49 AM |
Profire 2626 buffer size - any less than 256? | risemymuffins | Pro Tools M-Powered (Win) | 2 | 10-05-2010 08:58 PM |
Problem Solved--Profire 2626 DSP Mixer buffer is locked on 64 Bits | ubrnostrum | Pro Tools M-Powered (Win) | 1 | 04-20-2010 12:36 PM |
