Will any of the white AVID pci exp.chassis work with 24mix?
Has anyone successfully used a white AVID expansion chassis with a 24mix tdm system running 6.4.1 on a mac g4 quicksilver? These are alot easier to find than the black Digidesign chassis! I wonder if anyone on here has tried it to find out? I bet it will work because they both look identicle on the inside.
Re: Will any of the white AVID pci exp.chassis work with 24mix?
Anyone have info on this..? I'm interested as well..!
I believe the AVID's use 18-bit convertors. I think at the time, they were the esoteric high end used in the professional video world in the early-mid 90s...
Life is too short to play cover songs. . . |
Yes they use 18 bit converters.
The biggest issue with them is the meters only have 3 segments. That and they are that ugly beige color. They also will not work on the legacy port of an HD interface. But they do pass 24 bit through their AES/EBU I/O, that's what I used to use them for. |
I actually purchased one on ebay hoping it works. I'll let you know if it works in my Mix system. I struggled going between the AVID 888 and a 888/24. It was a $200 difference and my Digitech 400 only has 18-bit convertors anyways which is where I'd be using 4 channels of the Avid 888, so it's a wash.
From what I can tell they support 104db ceiling to noise floor which is probably better than the S/N in my home studio.
The OP is asking about the PCI Expansion Chassis, not the 888. Why is everyone discussing the audio interface?
Regarding the Chassis, I haven't tried it, but I don't see why it would make any difference. Afterall, both the digi and avid chassis were Magma products which were just re-badged. If the the digi one or the OEM magma one work (which they do) I would imagine the Avid one would too. They're cheap enough to try out anyway. |
Help! sbs Ext. Chassis/ 24mix No-see | lumpstar | Pro Tools TDM Systems (Mac) | 6 | 02-06-2009 09:05 AM |
avid expansion chassis problems | ak47 | Pro Tools TDM Systems (Mac) | 2 | 04-05-2007 10:38 AM |
Avid, Magma or SBS Chassis? HD3a-G4 | TCDet | Pro Tools TDM Systems (Mac) | 0 | 01-05-2005 03:44 AM |
Avid 888 (white face) same as standard 888? | ClickRec | Pro Tools TDM Systems (Mac) | 2 | 11-08-2003 11:08 PM |
Avid Expansion Chassis/680X0 ECI/PM8100 | Craig Learmont | Pro Tools TDM Systems (Mac) | 0 | 06-07-2000 03:44 PM |
