If MacMini has 5400 RPM HD how it will run PT LE 7.3?
Hi friends,
I´m confused... At this page: http://www.digidesign.com/index.cfm?...5&itemid=24156 Digidesign say Mac Mini is good to work with Pro Tools 7.3. But at this: http://www.digidesign.com/index.cfm?...4&itemid=23142 Digidesign say a 7200 RPM Hard Drive is the minimum to Pro Tools works well. But, if all MacMini have 5400 RPM Hard Drive how is possible it to be a good choice? Thanks Marcos Vampa |
Re: If MacMini has 5400 RPM HD how it will run PT LE 7.3?
Recording to system drive is never supported or recommended. It *might* work, but it might just as well not. As you cannot have two hard drives in a Mac Mini, you will need an external hard drive.
Or may I install all PT stuff on external HD? And is it possible or recommended to have two different velocities HDs at same time (5400 and 7200)? Thanks, Marcos Vampa |
the proper way would be to install pro tools on the system drive (internal), then create your pro tools projects on the external drive. if you create your projects on a drive, pt automatically creates a folder and puts all audio files in it..
Look, I don´t know, really, if 5400 is slow, I just guess I saw a contradiction comparing two Digidesign web pages about minimum requirements... I still am in doubt if MacMini is really a good choice. Thanks Marcos Vampa |
digi recomends that you "record" to a drive that is at least 7200. trust me, 5400 rpm is plenty fast for a system drive. i have a macbook pro with a 5400 rpm internal drive. i record to external 7200 rpm firewire drive. works perfectly.. heck, i have even recorded multiple tracks to the internal drive with no problems...
OK, you convinced me.
I will wait a friend that travel to USA to bring a MacMini and an external HD for me. Here in Brazil a Mac costs twice the price in USA! ... believe me... Thanks, Marcos Vampa |
This is all good to know, but I've also been wanting to know if anyone has had any luck with the Lightbridge and a Mac Mini.
My current Mac, a G4 w/an accelerator card, won't work with the Lightbridge. I get pops and clicks that M-Audio claims is due to the card. The LB only has 1 FW port as well. I'm hoping it gets a long with a Mini and a daisy-chained outboard FW drive. Any thoughts? |
PTLE on XP on MacMini? | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-03-2006 12:08 AM |
PTLE on XP on MacMini? | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-02-2006 09:18 AM |
macmini question. | karllinus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-11-2006 03:05 PM |
MacMini with Lacie HD too hot? | bart vleugels | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-08-2006 09:23 AM |
CPU Upgrade or buy a MacMini | djwilmer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-19-2005 07:55 AM |
