Linking same plugin parameters
So there's a feature I'm trying to recreate where one can copy an instance of a plugin to another track, and then change the same parameter of both plugins at the same time by doing it on only one plugin. It used to happen years ago without me knowing how or why.
It doesn't seem to be related to Groups as I've tried that.
MacBook Pro (16-inch, 2019), 2.3 GHz 8-Core i9, 16 GB RAM, macOS 10.15.7. M1 Mac mini, 16 GB RAM, macOS 11.6.4. Mac Pro (Late 2013), 3.5 GHz 6-Core Intel Xeon E5, 16 GB RAM, macOS 12.2.1. Pro Tools 2021.10 Cubase Pro 11.0.41 Logic Pro X 10.6.3 Apollo Twin DUO MKII UAD-2 Satellite QUAD Thunderbolt |
Re: Linking same plugin parameters
It definitely *is* groups: Be sure that the plugins are linked in the groups attributes dialog.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
That^^^ or instead of using the same plugin on several tracks, bus the tracks thru an AUX track(or a new routing folder) and insert a single plugin on the AUX track. You can also Ctrl-drag the plugin again(with the new change) and replace the previously copied plugin.
It was the attributes, thanks!
And thanks for the other tip, I'm already aware of it, but I wanted to learn specifically how that feature worked.
how should we map plugin parameters on S3? | cebolao | Avid S1, S3, Dock and Control App | 0 | 03-31-2020 03:00 PM |
Linking multiple plug-in parameters while maintaining relative values | raal | Tips & Tricks | 4 | 04-28-2019 02:02 PM |
Linking Plugin parameters | w3ird | Tips & Tricks | 6 | 11-01-2008 08:41 AM |
linking aphex stereo plug-in parameters | c-post | Pro Tools TDM Systems (Mac) | 3 | 06-14-2007 09:14 AM |
plugin automation parameters are gone | RCN | Pro Tools TDM Systems (Mac) | 4 | 12-12-2005 12:44 PM |
