#21
Re: Constant error messages (-6101), (-9128)
I've never used the Mbox2 Pro with its power supply, only through firewire; I also use a Command 8, which by the way has often another strange behaviour, tho not related with the these dae errors; it happens that when I switch on the Command8 it doesn't follow the usual start up routine, instead the faders do not move and the lcd display is half visible, but what's worse, PT do not recognise it; so I try switching off and on the unit for several time untill it get back to the normal state, but this doesn't always help, often I have to wait hours or days before getting it to work again; I controlled the output voltage of the Command8 power supply, which seems to be normal; anyway, the error messages appear also with the Command8 not connected to the G5_
Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. -Scott Adams, cartoonist (1957) |
#22
yeah, i'm still using tiger and PT 7... regardless, it all seems preventable on PT's end(like make a version that doesn't go to crap if you don't think to do a clean uninstall of the last version)... or at the very least foreseeable and provide some serious warnings or instructions of some kind. i upgraded to tiger specifically for the mbox2 and PT 7. man i wish i hadn't. sorry... i'm just real frustrated. |
#23
Just to be clear - I need to know ALL the devices attached to your computer, including keyboards, mice, hubs, printers, hard drives, etc and to which port they're connected. |
#24
#25
Have you gone through all the optimizations in the General Troubleshooting thread yet? Can you please post a plug-in version list using the Tech Support Utility from that thread? |
#26
unfortunately the unit is no longer in warranty, I called the tech support here in Italy and they told me that probably it would cost so much to repair it that would be better to buy a new one, which is not very encouraging as answer; btw, I did all of the optimizations suggested in the General Troubleshooting thread, I also disconnected the Airport base and every device but the keyboard and the mouse; i run the TSU to generate the version list, which oddly enough shows like this: Sat Feb 21 19:22:27 CET 2009 Pro Tools Version __________________________________________ Plug-In Versions __________________________________________ AIRChorus.dpm AIRDistortion.dpm AIRDynamicDelay.dpm AIREnhancer.dpm AIREnsemble.dpm AIRFilterGate.dpm AIRFlanger.dpm AIRFrequencyShifter.dpm AIRFuzz-Wah.dpm AIRKillEQ.dpm AIRLo-Fi.dpm AIRMulti-Chorus.dpm AIRMulti-Delay.dpm AIRNon-linearReverb.dpm AIRPhaser.dpm AIRReverb.dpm AIRSpringReverb.dpm AIRStereoWidth.dpm AIRTalkbox.dpm AIRVintageFilter.dpm BF Essential Clip Remover.dpm BF Essential Corr.dpm BF Essential Meter.dpm BF Essential Noise.dpm BF Essential Tuner.dpm Boom.dpm Broadband Noise Reduction LE.dpm Chorus.dpm Click.dpm D-Verb.dpm DB-33.dpm DigiReWire.dpm Dither.dpm Dynamics III.dpm EQ III.dpm Elastic Audio.dpm Eleven Free.dpm Flanger.dpm Funk Logic Masterer.dpm Hybrid Hybrid.dpm Invert-Duplicate.dpm LoFi.dpm Maxim.dpm MiniGrand.dpm Mod Delay II.dpm Multi-Tap Delay.dpm Normalize-Gain.dpm Ping-Pong Delay.dpm RectiFi.dpm Reverse-DC Removal.dpm SansAmp PSA-1.dpm SciFi.dpm Signal Generator.dpm SignalTools.dpm Smack! LE.dpm SoundReplacer.dpm Structure.dpm TL AutoPan.dpm TL InTune.dpm TL MasterMeter.dpm TL Metro.dpm TL Space Native.dpm Time Comp-Exp-Pitch Shift.dpm Time Shift.dpm TimeAdjuster.dpm Trim.dpm Vacuum.dpm VariFi.dpm XPand!.dpm bombfactory BF76.dpm Plug-Ins Unused Versions __________________________________________ Dynamics II.dpm EQ II.dpm Toolkits and Digitranslator Versions __________________________________________ Music Production Toolkit DV Toolkit 2 is not installed Digitranslator 2 is not installed Digitranslator 1 is not installed it seems that no versions have been detected, and I repeated it several times_
#27
I too am having all the problems described here. My issue can be - at this point - narrowed to any session that has Reason in it. For example: I have a session with one MIDI track and one instrument track. The instrument track has reason in it running 1 combinator and 1 dr rex loop. It is 45 seconds long and it's a miracle if it will get all the way through. My installation process was
I have installed OS 10.5.6 I have done a clean install of PT 8 I reinstalled Reason, when I knew I had a problem. I have - i believe - updated or deleted any non-leopard compatible plugins (list to follow) I have followed all the advice listed on your sticky eg deleting pref, databases etc and I still can't get it to work smoothly My system spec is Model Name: Mac Pro Model Identifier: MacPro1,1 Processor Name: Dual-Core Intel Xeon Processor Speed: 2.66 GHz Number Of Processors: 2 Total Number Of Cores: 4 L2 Cache (per processor): 4 MB Memory: 4 GB My Plug in list - as with the above poster - does not seem to have any version numbers. It's interesting that of all the posters on this thread only he and I are running 10.5.6. PLEASE PLEASE PLEASE can we get this solved. Sun 22 Feb 2009 01:05:50 GMT Pro Tools Version __________________________________________ Pro Tools LE.app Plug-In Versions __________________________________________ AIRChorus.dpm AIRDistortion.dpm AIRDynamicDelay.dpm AIREnhancer.dpm AIREnsemble.dpm AIRFilterGate.dpm AIRFlanger.dpm AIRFrequencyShifter.dpm AIRFuzz-Wah.dpm AIRKillEQ.dpm AIRLo-Fi.dpm AIRMulti-Chorus.dpm AIRMulti-Delay.dpm AIRNon-linearReverb.dpm AIRPhaser.dpm AIRReverb.dpm AIRSpringReverb.dpm AIRStereoWidth.dpm AIRTalkbox.dpm AIRVintageFilter.dpm AmpegSVXUNO.dpm BF Essential Clip Remover.dpm BF Essential Corr.dpm BF Essential Meter.dpm BF Essential Noise.dpm BFD2.dpm Boom.dpm Chorus.dpm Click.dpm Cosmonaut Voice.dpm D-Verb.dpm DB-33.dpm DigiReWire.dpm Dither.dpm Dynamics III.dpm EQ III.dpm Elastic Audio.dpm Eleven Free.dpm Flanger.dpm Invert-Duplicate.dpm JOEMEEK Compressor.dpm JOEMEEK Meequalizer.dpm L2007 Mastering Limiter.dpm LoFi.dpm Massey CT4.dpm Maxim.dpm MiniGrand.dpm Mod Delay II.dpm Multi-Tap Delay.dpm Normalize-Gain.dpm Ping-Pong Delay.dpm RectiFi.dpm Reverse-DC Removal.dpm SampleTank2.xSE.dpm SansAmp PSA-1.dpm SciFi.dpm Signal Generator.dpm SignalTools.dpm Structure.dpm TL AutoPan.dpm TL InTune.dpm TL MasterMeter.dpm TL Metro.dpm TRackS1.xEQ.dpm Tape-Head.dpm Tel-Ray Delay.dpm Time Comp-Exp-Pitch Shift.dpm Time Shift.dpm TimeAdjuster.dpm Trim.dpm Vacuum.dpm VariFi.dpm Voce Chorus-Vibrato.dpm Voce Spin.dpm XPand!.dpm bombfactory BF-3A.dpm bombfactory BF76.dpm vt3.dpm Plug-Ins Unused Versions __________________________________________ BF Essential Tuner.dpm Dynamics II.dpm EQ II.dpm Funk Logic Masterer.dpm moogerfooger AD.dpm moogerfooger RM.dpm Toolkits and Digitranslator Versions __________________________________________ Music Production Toolkit is not installed DV Toolkit 2 is not installed Digitranslator 2 is not installed Digitranslator 1 is not installed Complete Production Toolkit is not installed |
#28
sorry I forgot tosay I am using the 002 R (it's been along day!)
#29
topic dead?
#30
zeze:
To get the version list, firstly you need to have the pro tools program started. Secondly, the file to which the version list is written must _not_ exist previously, if it does, delete it or at least move or rename it. |
ERROR -6101 constant | bakerja | Pro Tools 11 | 11 | 11-08-2013 07:27 AM |
error messages: -6101 & -9128 appears regularly :( | kolargol | macOS | 0 | 01-26-2013 07:37 PM |
-6101 error messages, M Box 2 Pro | edfreeze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-10-2009 11:29 AM |
Constant H/W buffer errors -6101 -6104 -9128 | alvarez1900 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 01-08-2009 11:58 PM |
cpu error 6101&9128 | gIbson_19 | Pro Tools M-Powered (Mac) | 0 | 10-30-2006 12:40 AM |
