Old 05-15-2022, 02:20 PM
XJENSEN XJENSEN is offline
Default Switching playlists of individual tracks inside folder track?
Does anyone observe this behaviour?
Whenever I use Shift + Up/Down arrows, to run through playlists of a single selected (MIDI) track inside a folder track, all the other tracks inside that folder also switch playlists.
This is extremely annoying and I could not find a setting that disables this. Is this normal behaviour? Because if so, this is another reason these folder tracks are completely unusable to me. Is there any setting that disables this?
Old 05-15-2022, 02:49 PM
BScout BScout is offline
Default Re: Switching playlists of individual tracks inside folder track?
Certain your tracks aren't grouped?
Old 05-17-2022, 01:28 AM
Good point, but no, they aren't.
Restarting Pro Tools solved the problem for now.
I noticed that some other tracks also switched playlists randomly, which messed up my whole session, so I had to go back to a previous version.
I'll keep an eye on this...
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
Show tracks inside folders with folder hidden snowplaysmusic Pro Tools 3 06-22-2021 03:58 PM
Is there a way to select Routing folder without selecting tracks inside? Protone Pro Tools 2020 0 03-27-2021 04:35 AM
Switching playlists with multiple tracks all at once? anackman Pro Tools 10 3 12-13-2015 05:31 PM
Track Comping/Switching between playlists will the moor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-14-2005 07:48 PM
