Old 12-14-2008, 11:41 AM
CrAkD CrAkD is offline
Default viewing numerican master fader meter?
I wanna see the actual db level the fader is hitting is there anyway to do this?
i7 920, Gigabye ud4p, 12gb OCZ Platinum ddr3 1600, 2x 640gb WD Caviar Black 1x Samsung 120gb SSD
HACKINTOSH Mac OSX 10.8 Pro Tools 10.2
OLD Dverb 1024 - 520 Dverbs 64 - 433 Dverbs
NEW Dverb 1024 - 283 64 - 235
Old 12-15-2008, 02:38 AM
tbkbt tbkbt is offline
Default Re: viewing numerican master fader meter?
I know you can see at what level you have the fader if you look below it, if you then control click this you scroll through a couple of other values, one is the delay(in samples i believe) and the other is the peak value of the waveform that has been(to reset this i think you windows click(possibly)) I'm not sure if there is any way to show the constantly changing level of the waveform though. There may possibly be a plugin meter that can do this but sorry I don't know anything about them, hope this helps
Old 12-15-2008, 05:38 PM
Wango Wango is offline
I'd like to see this also. I haven't found a way to make it happen.
In fact, I'd like to see numeric values for all the faders - just the highest peak value.
Wango
Don’t piss down my back and tell me it’s raining.
http://www.soundclick.com/bands/defa...?bandID=851389
Old 12-15-2008, 06:45 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
As the earlier poster said, to do this just hold ctrl+alt & click & it will change all tracks to where u can see the peaks numerically...It'd be in the same place where u see the volume(hence thatz where u would click; & u can also click again to see samples)...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 06:36 AM
Master fader and meter readings jasonthurley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2010 10:48 PM
Fader Meter Behavior in PT8 and Fader Weights DrFord Pro Tools TDM Systems (Mac) 4 01-08-2009 03:23 PM
Level meter on Multichannel Master Fader Redbeard Post - Surround - Video 4 07-24-2003 06:34 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 08:41 AM
