Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 04-23-2008, 08:54 AM
BenPomphrett BenPomphrett is offline
Default Pro Tools M-Powered failing to launch
Mac Book Pro 2.33GHz Intel Core 2 Duo
2GB Memory
Running Mac OS X 10.4.11 and M-Audio ProjectMix I/O
Hey all.
Recently upgraded to OS X 10.4.11 using Software Update to find on installing Pro Tools 7 (then updated to 7.3.1 cs6) fails to launch. Searched Digidesign help which recommended installing 10.4.11 Combo update. Did this but still fails to launch. Program loads until "Setting Up Peripherals" dialog and then quits.
Any hints or tips on how to fix this? Not sure if Pro Tools 7.3.1 is maybe not compatible with OS X 10.4.11 yet, so if someone could clarify, that would be great. Please find below a copy of the Problem Report generated when Pro tools quits.
Many thanks,
Ben.
Date/Time: 2008-04-23 15:55:45.542 +0100
OS Version: 10.4.11 (Build 8S2167)
Report Version: 4
Command: Pro Tools M-Powered
Path: /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/MacOS/Pro Tools M-Powered
Parent: WindowServer [207]
Version: 7.3.1cs6 (7.3.1f132)
PID: 395
Thread: 15
Exception: EXC_BREAKPOINT (0x0006)
Code[0]: 0x00000002
Code[1]: 0x00000000
Thread 0:
0 DigiMachOServices 0x05be8432 TouchPageOverlapCheck(unsigned, unsigned) + 262
1 DigiMachOServices 0x05be869c findmem() + 454
2 DigiMachOServices 0x05be872f DSI_PageMemoryOp + 21
3 com.digidesign.framework.DSI 0x01f4d3ab DsiPageMemoryOp + 23
4 com.digidesign.framework.DAE 0x034f93bb FicLockAllMemoryBlocks + 43
5 com.digidesign.framework.DAE 0x03449c27 FWDeviceCallback + 141989
6 com.digidesign.framework.DAE 0x03454772 FWDeviceCallback + 185840
7 com.digidesign.framework.DAE 0x034549c2 FWDeviceCallback + 186432
8 com.digidesign.framework.DAE 0x034ba2a8 FWDeviceCallback + 602406
9 com.digidesign.framework.DAE 0x033fa2ab FicReportExternalEvent + 47741
10 com.digidesign.framework.DAE 0x033f9f0a FicReportExternalEvent + 46812
11 com.digidesign.framework.DAE 0x033fac94 FicReportExternalEvent + 50278
12 com.digidesign.framework.DAE 0x034e8e63 FicAcquire + 25
13 com.digidesign.ProToolsMP 0x007eb86a start + 8294078
14 com.digidesign.ProToolsMP 0x007f09ef start + 8314947
15 com.digidesign.ProToolsMP 0x007f0d82 start + 8315862
16 com.digidesign.framework.DFW 0x029cb648 TCommandHandler::PerformCommand(TCommand*) + 64
17 com.digidesign.framework.DFW 0x029cbe65 TCommand::Process() + 31
18 com.digidesign.framework.DFW 0x029c2efe TApplication::ProcessEvent(TEvent*) + 26
19 com.digidesign.framework.DFW 0x029c40c8 TApplication::WakeUp() + 48
20 com.digidesign.framework.DFW 0x02a593a7 TApplication::GetApplicationVersionComponents(Cmn_ PolyVector<long, (bool)0>*) + 587
21 com.apple.HIToolbox 0x92dee4d7 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1093
22 com.apple.HIToolbox 0x92dedb7c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
23 com.apple.HIToolbox 0x92deda41 SendEventToEventTargetWithOptions + 55
24 com.apple.HIToolbox 0x92df50e3 ToolboxEventDispatcherHandler(OpaqueEventHandlerCa llRef*, OpaqueEventRef*, void*) + 357
25 com.apple.HIToolbox 0x92dee88e DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2044
26 com.apple.HIToolbox 0x92dedb7c SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 304
27 com.apple.HIToolbox 0x92df4f7c SendEventToEventTarget + 56
28 com.apple.HIToolbox 0x92e38eb3 ToolboxEventDispatcher + 81
29 com.apple.HIToolbox 0x92e378cb RunApplicationEventLoop + 165
30 com.digidesign.framework.DFW 0x02a48e5d DFW_EventLoop::RunApplicationEventLoop() + 11
31 com.digidesign.framework.DFW 0x029c2dc1 TApplication::MainEventLoop() + 11
32 com.digidesign.framework.DFW 0x029c2f6b TApplication::Run() + 39
33 com.digidesign.ProToolsMP 0x00d4f113 start + 13944679
34 com.digidesign.ProToolsMP 0x00002aae start + 258
35 com.digidesign.ProToolsMP 0x000029d5 start + 41
Thread 1:
0 libSystem.B.dylib 0x90047dd7 semaphore_timedwait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90ce1da5 TSWaitOnSemaphoreCommon + 163
2 ...ple.CoreServices.CarbonCore 0x90ce8d8d TimerThread + 87
3 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 2:
2 ...ple.CoreServices.CarbonCore 0x90cec9e9 DeferredTaskThread + 57
Thread 3:
0 libSystem.B.dylib 0x90026d5c kevent + 12
1 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51
2 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 4:
0 libSystem.B.dylib 0x900248c7 semaphore_wait_signal_trap + 7
1 ...ple.CoreServices.CarbonCore 0x90cb8e0d MPWaitOnQueue + 198
2 com.apple.DesktopServices 0x9271e953 TNodeSyncTask::SyncTaskProc(void*) + 143
3 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51
4 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 5:
0 libSystem.B.dylib 0x90037b57 mach_wait_until + 7
1 ...ple.CoreServices.CarbonCore 0x90ce6315 Delay + 118
2 ...opellerheads.rewire.library 0x1a3d67e8 RWPUnregisterDeviceImp + 21574
3 ...opellerheads.rewire.library 0x1a3f1a5c RWPUnregisterDeviceImp + 132794
Thread 6:
0 libSystem.B.dylib 0x90009cd7 mach_msg_trap + 7
1 com.apple.CoreFoundation 0x9082d253 CFRunLoopRunSpecific + 2014
2 com.apple.CoreFoundation 0x9083e128 CFRunLoopRun + 60
3 com.apple.DVCPROHDMuxer 0x1b4170fb AVS:estroyAVCDeviceController(AVS::AVCDeviceCont roller*) + 297
Thread 7:
2 com.apple.CoreFoundation 0x9082ca6e CFRunLoopRunInMode + 61
3 com.apple.audio.CoreAudio 0x91469356 HALRunLoop::OwnThread(void*) + 158
4 com.apple.audio.CoreAudio 0x91469171 CAPThread::Entry(CAPThread*) + 93
5 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 8 Crashed:
0 dyld 0x8fe053f6 dyld::bindLazySymbol(mach_header const*, unsigned long*) + 384
1 dyld 0x8fe131af stub_binding_helper_interface + 61
2 <<00000000>> 0x00000000 0 + 0
Thread 9 Crashed:
Thread 10 Crashed:
Thread 11 Crashed:
Thread 12 Crashed:
Thread 13 Crashed:
Thread 14 Crashed:
Thread 15 Crashed:
Thread 16:
0 libSystem.B.dylib 0x901101bf semaphore_timedwait_trap + 7
1 com.digidesign.framework.DAE 0x034504bd FWDeviceCallback + 168763
2 ...n.framework.PlatformSupport 0x01fda5cb PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 10685
Thread 17:
1 ...gn.framework.CoreFoundation 0x028345e6 Sys_AtomicInt32::Exchange(long) + 236
2 com.digidesign.ProToolsMP 0x00d5e37c start + 14006736
3 ...gn.framework.CoreFoundation 0x028b6e72 Sys_RawThreadTask::Run() + 60
4 ...gn.framework.CoreFoundation 0x0286a6d8 Sys_RawThread::GetCurrentThreadID() + 112
5 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51
6 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 18:
1 ...gn.framework.CoreFoundation 0x02869a56 Sys_RawEventMacOS::Wait(long) + 38
2 com.digidesign.ProToolsMP 0x00cd3af1 start + 13439301
Thread 19:
0 libSystem.B.dylib 0x9001a1cc select + 12
1 libSystem.B.dylib 0x90024227 _pthread_body + 84
Thread 20:
0 libSystem.B.dylib 0x900bc26c sem_wait + 12
1 com.digidesign.framework.DAE 0x034477f6 FWDeviceCallback + 132724
2 com.digidesign.framework.DAE 0x03493876 FWDeviceCallback + 444148
Thread 21:
1 com.digidesign.framework.DAE 0x0344781b FWDeviceCallback + 132761
Thread 22:
1 com.digidesign.framework.DAE 0x033d6c5b FicGetApplicationInterface + 202637
2 ...ple.CoreServices.CarbonCore 0x90cb8c68 PrivateMPEntryPoint + 51
Thread 23:
1 com.digidesign.framework.DAE 0x03472d6d FWDeviceCallback + 310251
Thread 15 crashed with X86 Thread State (32-bit):
eax: 0x8fe548c0 ebx: 0x8fe05284 ecx: 0x00000000 edx: 0x00000000
edi: 0x01e17810 esi: 0x8fe548c0 ebp: 0xb070de78 esp: 0xb070de40
ss: 0x0000001f efl: 0x00000292 eip: 0x8fe053f6 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
Binary Images Description:
0x1000 - 0x13e5fff com.digidesign.ProToolsMP 7.3.1cs6 (7.3.1f132) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/MacOS/Pro Tools M-Powered
0x1da4000 - 0x1dcdfff com.digidesign.framework.CFD 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/CFD.framework/Versions/A/CFD
0x1de3000 - 0x1de5fff libFicClockComponent.dylib /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/libFicClockComponent.dylib
0x1f05000 - 0x1f15fff com.digidesign.framework.DMC 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/DMC.framework/Versions/A/DMC
0x1f25000 - 0x1f8dfff com.digidesign.framework.DSI 7.3 (7.3f117) /Library/Frameworks/DSI.framework/Versions/A/DSI
0x1fd1000 - 0x1fe6fff com.digidesign.framework.PlatformSupport 7.3 (7.3f117) /Library/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport
0x2808000 - 0x2907fff com.digidesign.framework.CoreFoundation 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/CFnd.framework/Versions/A/CFnd
0x2995000 - 0x2b21fff com.digidesign.framework.DFW 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/DFW.framework/Versions/A/DFW
0x2c22000 - 0x2fbbfff com.digidesign.framework.FileFormat 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt
0x3346000 - 0x36fbfff com.digidesign.framework.DAE 7.3.1cs3 (7.3.1f126) /Library/Frameworks/DAE.framework/Versions/A/DAE
0x3a0b000 - 0x3bcffff com.digidesign.framework.DHS 7.3 (7.3f117) /Library/Frameworks/DHS.framework/Versions/A/DHS
0x3c1e000 - 0x3ef6fff libNeoAccessPro.dylib /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/libNeoAccessPro.dylib
0x3fd5000 - 0x40affff libOMFToolkit.dylib /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/Frameworks/libOMFToolkit.dylib
0x40c7000 - 0x4121fff com.digidesign.framework.DirectIO 7.3.1cs2 (7.3.1f125) /Library/Frameworks/DirectIO.framework/Versions/A/DirectIO
0x4369000 - 0x43c3fff com.digidesign.framework.DUI 7.3 (7.3f117) /Library/Frameworks/DUI.framework/Versions/A/DUI
0x43d9000 - 0x4421fff com.digidesign.framework.DSPManager 7.3 (7.3f117) /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager
0x46c6000 - 0x4729fff [Unknown Bundle] [Unknown Bundle]
0x50db000 - 0x50defff com.apple.LiveType.component 2.1.3 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x50e3000 - 0x5148fff com.apple.LiveType.framework 2.1.3 /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
0x5170000 - 0x51e1fff com.DivXInc.DivXDecoder 6.4.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x51ef000 - 0x5235fff com.apple.motion.component 1.0 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x523a000 - 0x523dfff Motion /Library/Frameworks/Motion.framework/Versions/A/Motion
0x5394000 - 0x53f7fff [Unknown Bundle] [Unknown Bundle]
0x549a000 - 0x54fdfff [Unknown Bundle] [Unknown Bundle]
0x571b000 - 0x577ffff [Unknown Bundle] [Unknown Bundle]
0x5a62000 - 0x5a6afff com.apple.iokit.IOUSBLib 2.7.5 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x5bd7000 - 0x5bf7fff DigiMachOServices 7.3 (7.3f117) /Library/Frameworks/DigiMachOServices.framework/DigiMachOServices
0x5c15000 - 0x5c25fff DigidesignUSBDriver 7.4 (7.4f309) /Library/Frameworks/DigidesignUSBDriver.framework/DigidesignUSBDriver
0x1a34d000 - 0x1a39efff com.digidesign.plugin.DigiReWire 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/DigiReWire.dpm/Contents/MacOS/DigiReWire
0x1a3cb000 - 0x1a42afff se.propellerheads.rewire.library 1.7 /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle/Contents/MacOS/ReWire
0x1a449000 - 0x1a802fff se.propellerheads.reason.engine 3.0.5 /Applications/Reason/Reason.app/Contents/PlugIns/Reason Engine.plugin/Contents/MacOS/Reason Engine
0x1a8dd000 - 0x1a93ffff com.digidesign.plugin.SignalGenerator 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Signal Generator.dpm/Contents/MacOS/Signal Generator
0x1a9bb000 - 0x1aa11fff com.apple.DVCPROHDAudio 1.3 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
0x1b405000 - 0x1b44ffff com.apple.DVCPROHDMuxer 1.3 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x1b4c5000 - 0x1b4cafff com.apple.audio.AppleHDAHALPlugIn 1.3.7 (1.3.7a23) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1b4ce000 - 0x1b4defff com.digidesign.iokit.digifwdriver 7.4 (7.4f309) /Library/Frameworks/DigidesignFWDriver.framework/DigidesignFWDriver
0x1b736000 - 0x1b74ffff com.apple.IOFireWireLib 2.6.0 /System/Library/Extensions/IOFireWireFamily.kext/Contents/PlugIns/IOFireWireLib.plugin/Contents/MacOS/IOFireWireLib
0x1c905000 - 0x1cb8ffff com.digidesign.plugin.AAFCOAPI 7.3.1cs5 (7.3.1f131) /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/PlugIns/AAFCOAPI.bundle/Contents/MacOS/AAFCOAPI
0x1cccf000 - 0x1cd37fff com.digidesign.plugin.Dither 7.3 (7.3f117) /Library/Application Support/Digidesign/Plug-Ins/Dither.dpm/Contents/MacOS/Dither
0x8f8c0000 - 0x8f95ffff com.apple.QuickTimeImporters.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x8fe00000 - 0x8fe4afff dyld 46.16 /usr/lib/dyld
0x90000000 - 0x90171fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
0x901c1000 - 0x901c3fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
0x901c5000 - 0x90202fff com.apple.CoreText 1.1.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90229000 - 0x902fffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9031f000 - 0x90774fff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9080b000 - 0x908d3fff com.apple.CoreFoundation 6.4.8 (368.31) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x90911000 - 0x90911fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90913000 - 0x90a07fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
0x90a57000 - 0x90ad6fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
0x90aff000 - 0x90b63fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
0x90bd2000 - 0x90bd9fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
0x90bde000 - 0x90c51fff com.apple.framework.IOKit 1.4.8 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90c66000 - 0x90c78fff libauto.dylib /usr/lib/libauto.dylib
0x90c7e000 - 0x90f24fff com.apple.CoreServices.CarbonCore 682.28 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x90f67000 - 0x90fcffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x91008000 - 0x91047fff com.apple.CFNetwork 129.22 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9105a000 - 0x9106afff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
0x91075000 - 0x910f4fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x9112e000 - 0x9114cfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x91158000 - 0x91166fff libz.1.dylib /usr/lib/libz.1.dylib
0x91169000 - 0x91308fff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
0x91406000 - 0x9140efff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x91415000 - 0x9141cfff libbsm.dylib /usr/lib/libbsm.dylib
0x91420000 - 0x91446fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x91458000 - 0x914cefff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9151f000 - 0x9151ffff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91521000 - 0x9154dfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x91560000 - 0x91634fff com.apple.ColorSync 4.4.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9166f000 - 0x916e2fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91710000 - 0x917b9fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x917df000 - 0x9182afff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91849000 - 0x9185ffff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9186b000 - 0x91886fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
0x91891000 - 0x918cefff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x918e2000 - 0x918eefff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x918f5000 - 0x91935fff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x91948000 - 0x919fafff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
0x91a40000 - 0x91a56fff libcups.2.dylib /usr/lib/libcups.2.dylib
0x91a5b000 - 0x91a79fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x91a7e000 - 0x91addfff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91aef000 - 0x91af3fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x91af5000 - 0x91b7dfff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
0x91b81000 - 0x91bbefff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x91bc4000 - 0x91bdefff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91be3000 - 0x91be5fff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x91be7000 - 0x91cc5fff libxml2.2.dylib /usr/lib/libxml2.2.dylib
0x91ce2000 - 0x91ce2fff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x91ce4000 - 0x91d72fff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91d79000 - 0x91d79fff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x91d7b000 - 0x91dd4fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91ddd000 - 0x91e01fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x91e09000 - 0x92212fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9224c000 - 0x92600fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x9262d000 - 0x9271afff libiconv.2.dylib /usr/lib/libiconv.2.dylib
0x9271c000 - 0x92799fff com.apple.DesktopServices 1.3.6 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x927da000 - 0x92a0afff com.apple.Foundation 6.4.9 (567.36) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x92b24000 - 0x92b3bfff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92b46000 - 0x92b9efff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x92bb2000 - 0x92bb2fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x92bb4000 - 0x92bc4fff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x92bd3000 - 0x92bdbfff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x92be1000 - 0x92be7fff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92bed000 - 0x92c7efff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x92c92000 - 0x92c96fff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92c99000 - 0x92cb7fff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92cc9000 - 0x92ccffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x92cd5000 - 0x92d38fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x92d5f000 - 0x92da0fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92dc7000 - 0x92dd5fff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92ddc000 - 0x92de1fff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92de6000 - 0x930dbfff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x931e1000 - 0x931ecfff com.apple.opengl 1.4.16 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9325c000 - 0x9325cfff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9325e000 - 0x93914fff com.apple.AppKit 6.4.9 (824.44) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x93c95000 - 0x93d10fff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x93d49000 - 0x93e02fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x93e45000 - 0x93e45fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x93e47000 - 0x94008fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9404e000 - 0x9408ffff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
0x94097000 - 0x940d1fff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x940d6000 - 0x940ecfff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x94280000 - 0x9428ffff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x94296000 - 0x942a1fff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x942ed000 - 0x94307fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9430d000 - 0x94624fff com.apple.QuickTime 7.4.1 (14) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x94a04000 - 0x94a21fff libresolv.9.dylib /usr/lib/libresolv.9.dylib
0x96506000 - 0x9653cfff com.apple.audio.midi.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x96905000 - 0x96905fff com.apple.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x96f74000 - 0x96f79fff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x9828f000 - 0x9910ffff com.apple.QuickTimeComponents.component 7.4.1 (14) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x99fd5000 - 0x99ff2fff com.apple.OpenTransport 3.0 /System/Library/PrivateFrameworks/OpenTransport.framework/OpenTransport
0x9a687000 - 0x9a705fff com.tcltk.tcllibrary 8.4.7 a /System/Library/Frameworks/Tcl.framework/Tcl
Model: MacBookPro2,1, BootROM MBP21.00A5.B01, 2 processors, Intel Core 2 Duo, 2.33 GHz, 2 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 1 GB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: AirPort Extreme, 1.2.2
Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS541616J9SA00, 149.05 GB
Parallel ATA Device: MAT****ADVD-R UJ-85J
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA
USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
FireWire Device: ProjectMix, M-Audio, Up to 400 Mb/sec
Old 04-23-2008, 10:35 AM
DigiTechSupt's Avatar
Default Re: Pro Tools M-Powered failing to launch
Have you tried trashing preferences yet?
Avid Audio Tech Support
Support FAQ
Old 04-23-2008, 03:55 PM
Yep, just done that. Deleted 'com.digidesign.protoolsTDM.plist', 'DAE Prefs' (folder), 'DigiSetup.OSX' and 'Pro Tools preferences' as suggested in another DUC thread.
Any suggestions?
Old 04-23-2008, 04:10 PM
Are you running the latest drivers for the ProjectMix? If not - update. If you are, I would try an uninstall and reinstall.
You can also try creating a new administrator account and test from there - it will reveal any problems with the current admin account.
Support FAQ
Old 04-25-2008, 10:38 AM
Hi.
Updated the ProjectMix drives to 10.4.11 (beta) as supplied on the M-Audio site. Once again, deleted all preference files and folders and restarted. Still not working. Uninstalled Pro Tools and reinstalled with update to 7.3. Still not working. Created new admin account and tried to run program from that. No success.
Completed stumped by this! Any ideas?
Ben.
Old 04-25-2008, 01:45 PM
JrummerJ JrummerJ is offline
Is the icon bouncing and then nothing happens? If so, search and find the prebinding script...run it.
J
Old 04-25-2008, 06:28 PM
Nope, it opens the program and runs the loading dialog to around the point of "Initialising Globals" (it gets this far sometimes, other times it doesn't) and then unexpectedly quits. Tried the prebinding script and was told it wasn't required.
Old 04-26-2008, 08:23 AM
bradch00 bradch00 is offline
Rather than performing the system cleanup (trashing the prefs) manually have you used the tech support folder script at least it insures that all the files have been deleted; http://www.digidesign.com/index.cfm?...4&itemid=25974
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 04-28-2008, 07:40 AM
Right, will try that too.
I see you (bradch00) are running 10.4.11 and Pro Tools 7.4 with a ProjectMix - I take it everything is working fine for you?
Maybe an update might sort it.
Old 04-28-2008, 03:45 PM
Yes I am running PT 7.4 M-Powered on OS X 10.4.11 on an intel iMac, projectMix I/O interface and everything works perfectly. I upgraded to the new (beta) M-Audio FW interface driver and it has fixed a few problems as well.
Failing to launch + Distorted Audio Hbthyname Windows 1 02-28-2011 03:09 AM
Video Engine Failing to Launch palmer_jankens Pro Tools TDM Systems (Mac) 2 12-01-2008 03:40 PM
Protools LE failing to launch sculptor 1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-02-2007 05:28 AM
Pro Tools M-Powered 7.1.1 doesn't launch heppner Pro Tools M-Powered (Mac) 2 09-29-2006 02:20 AM
7.2 install not working...failing to launch deerock Pro Tools TDM Systems (Mac) 2 08-12-2006 11:58 AM
