Old 07-28-2006, 07:13 PM
newtoPT newtoPT is offline
Default help - no sound when playing back audio track!
I just got PT LE 7 and have things set up - I've recorded an audio track (i can see all the sound waves and the levels are good), but I can't hear anything when I play back. I've selected the track, made sure that my mix is turned to playback and I have my headphones plugged into my mbox and the volume is on. Someone told me that I need to check my CPU to make sure that my audio is being fed through my mbox, but I'm new to all of this and I don't know how to check it on a mac. Any help would be greatly appreciated - I've been searching high and low... Any good books you'd recommend for a complete beginner? THANK YOU!
Old 07-29-2006, 11:25 AM
arneal arneal is offline
Default Re: help - no sound when playing back audio track!
Hi New,
To check to see if your audio is set to output thru the mBox, open System Preferences, click on the sound preference pane and make sure that Digidesign MBox is highlighted - that's it. If that doesn't solve it, in Pro Tools, go to Setup-Hardware-Clock. Whichever source is selected (Internal or S/PDIF), try the other one. At least, that's what works for me when the audio suddenly cuts out with no "Interrupt" error message. Hope this helps.
21.5" (Late-2015) 11,2 iMac i5 2.8GHz, 16Gb, PT 12.8.2, Metric-Halo ULN2 2d Exp'd w/Sierra 10.12.6
Old 07-29-2006, 11:57 AM
Hi Arneal,
Thanks for your reply - I changed the audio output to the mbox and also changed between the clock sources and still no sound. Any other advice? Thanks for giving me the instructions for the CPU output, common sense really - what a blonde moment! Thanks again.
New
Old 07-29-2006, 01:33 PM
Hey New,
Sorry that wasn't the ticket. I think I need to get my unit to an auth. tech, because what's happpening in my case shouldn't be happening - the sudden loss of audio without an error message during playback. For me switching the clock restores it temporarily.
Those were my only suggestions based on my limited (very!) knowledge. I hope you get some other responses,
Armond
No sound when playing back awds macOS 11 09-24-2012 04:44 PM
Track volume goes down when playing back! tunecrab Pro Tools M-Powered (Win) 1 05-23-2007 02:00 AM
No sound when playing back with record enabled mhvoiceuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-01-2007 12:27 PM
distorted sound while playing back ceyda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-15-2006 09:30 PM
Sound File Not Playing Back livstone Pro Tools TDM Systems (Mac) 3 03-11-2003 07:27 PM
