Old 09-09-2005, 11:00 AM
CHEEZGRITS CHEEZGRITS is offline
Default Give me an opinion on my mixing technique...PLEASE
I'm new to the protools/mixing world...if anyone has the time and can give constructive criticism, please check out my songs and give honest feedback...thanks soooo much!!!
http://www.myspace.com/beatdownboyz
all aboard. next stop...the road less traveled!
Old 09-09-2005, 03:00 PM
Pro Toolz LE Pro Toolz LE is offline
Default Re: Give me an opinion on my mixing technique...PLEASE
Sounds a little muffled and dirty. Could be a little cleaner, also seemed like your levels peaked on some tracks, but what do I know I may be just hearing sh*t. Other than that it sounds good. I'm sort of new too so If ya could do the same for me I would be happy to let u hear it. I rap too if ya thinking bout it.
Old 09-21-2005, 01:48 PM
Scotty_OiArT Scotty_OiArT is offline
You have skill so keep practising, it honestly sounds pretty good mix wise. The best advice I could provide to you is give the vocals a little more room in the mix... let em breathe, and with a little work they will start to work they're way to the front of the mix..
Vocals are just hiding a little bit behind the other insturments... they need to be out front a bit more
Add a little 250 hz to your mixes (should take care of a bit of the mudd)
Keep up the good work
Default Re: Give me an opinion on my mixing technique...PLEASE *DELETED*
Post deleted by Scotty_OiArT
Old 09-30-2005, 02:06 PM
Sharritan Sharritan is offline
I suggest you take some of the delay/reverb out of the backing/answering vocals. It makes it sound like it was dubbed in instead of being part of the main track. Not too bad though. There is just so many things going on. Maybe pull out the little effect running the whole song and put it in and out sparingly. You could start it at the dah-dah-dahs.
Good luck
Old 10-09-2005, 08:56 AM
HAIRCUTS91 HAIRCUTS91 is offline
it sounds great listen to my stuff and let me know what you think www.myspace.com/randmempire
Plugin Interface Design Survey - Give Your Opinion! Emz1137 Pro Tools 9 0 01-04-2012 05:40 AM
Berklee Online -Give me your opinion! vipercobra General Discussion 0 02-03-2009 08:37 AM
new song, please give opinion tjkili 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-08-2003 08:45 AM
New wishes for the Next PT LE PC version update, everyone please give your opinion yavuzj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 63 08-27-2001 10:54 PM
MIx plus with G4...please give opinion?? JT916 Pro Tools TDM Systems (Mac) 1 03-31-2000 12:39 AM
