Interesting Channel Strip behavior
I've been warming up to channel strip lately. I don't like that it doesn't have 6dB/8va filters, but that isn't necessarily a deal breaker. The really interesting thing about the plug is how different settings affect its efficiency.
As an experiment on my HD Native system (6 core Nehalem) I set up a dummy FX mix session with 172 mono tracks 12 5.0 food group auxes with Massey L2007 limiters on each and 12 corresponding 5.0 record tracks. I put 5 mono to stereo reverb sends on each audio track with 5 stereo aux reverb returns with Altiverb on each. Then I populated each of the 172 audio source tracks with Channel Strip and opened up the System Usage window to see where I stood. This is where it got interesting. If all the Channel Strip EQ bands were set to bell curves and all the individual processing modules were on, I was at 24% CPU usage. If I turned OFF the Expander module, the usage climbed to about 36%. If all the processes were on and I changed the high and low EQ bands to shelf, usage went up to about 54%. If I then turned off the expander the usage went to over 75% and was spiking wildly making it impossible to roll the system. I can understand how shelf EQ could use up a bit more CPU power, but why would turning off the Expander use up so much juice?
Gary Gegan |
Re: Interesting Channel Strip behavior
shelf behaviour is a bug.
try throwing an Eleven Free or an old waves 8 Q1 anywhere in the signal path of your session - the CPU usage will drop to half or less. after that you can remove the Eleven and the CPU will be stable. restart the session and you're back to square 1 with instance CPU usage. I prefer the shelf as default so I'm on waves 8 with an unused Q1 till there's a fix. justin |
Wow, that's just plain weird! But what about the Expander issue? That's even stranger than the shelf issue.
Gary Gegan |
strange indeed - so maybe also a bug.
if you can write up a recipe we might be able to get some traction on it. |
I'll try to distill the facts and relay them ASAP.
Gary Gegan |
Anyone using URS Channel Strip Pro? | ondruspat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-31-2008 04:40 PM |
Renaissance channel vs Channel Strip | frenchman | Tips & Tricks | 1 | 09-20-2003 05:18 AM |
Interesting PT6 behavior | Slim Shady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-09-2003 05:38 PM |
Interesting article re: Clear Channel | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-27-2003 07:32 AM |
DBX 376 Channel Strip | Yah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-07-2002 12:01 AM |
