Old 04-26-2006, 07:59 PM
tvlyd tvlyd is offline
Default Unable to firmware update 002R
Hi
Please help before I go crazy.
Just installed LE 7.1 and lastest cs updates on my G4 Powermac. During 002R system firmware updating the connection between 002R and the Mac disconnects. So no firmware updating is possible. Why does that happens. I'm loosing my mind. I don't know what to do.
Greetings
Tvlyd
PowerMac 1.2GHz 1.5GB RAM. Mac OSX 10.4.6
Old 04-27-2006, 09:14 PM
tha k man tha k man is offline
Default Re: Unable to firmware update 002R
Does the 002 disconnect any other time ? It's probably the power harness. Do a search on power harness, and you'll find stacks of info on what to do.
G5 Dual 1.8 /1.5 Gb Ram
OSX 10.4.7
PT LE 7.3 cs1
DIGI 002
Waves Ren
Sony Bundle
Soundtoys-arama
NI Komplete 3
Old 08-23-2006, 02:53 AM
mkaudio mkaudio is offline
no, it's not power harness.... Same thing happened to me a while ago when I tried to update my 002's firmware to v1.20... During the update the progress bar just stopped and the machine lost communication with the computer... Digi told me to send it back but I didn't do it since it would cost quiet a lot to send it half way around the world
anyways, if you come up with a solution, pls post it here... I'll do the same...
Aaaaight guys, I did it!!!!!
You need to press ESC + Display + REC at the same time and hold them down while turning 002 on... It's gonna reset to factory settings. Fantastic that I'm able to use it again after that much time!!!
Old 08-27-2006, 01:07 AM
JohnnyG JohnnyG is offline
Unfortunetly, the 002r doesn't have a firmware updater the way the 002 does. If it's not the power harness issue, then you're going to have to send it in to Digi or bring it into an Authorized Repair center.
Unable to update Digi 003+ Firmware to 8.0.1 on Vista x86 vikingwiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-01-2009 12:43 PM
New user unable to process a firmware update in XP dbcalsax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-03-2005 03:11 PM
New user unable to process a firmware update in XP dbcalsax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-03-2005 02:54 PM
Unable to update Sync I/O firmware Samhein Pro Tools TDM Systems (Mac) 1 05-07-2002 10:18 AM
Unable to update USD Firmware via DigiSerial Port Samhein Pro Tools TDM Systems (Mac) 13 11-05-1999 03:17 PM
