Old 09-12-2008, 09:30 AM
karli456 karli456 is offline
Default Color Coding
I recently worked with an engineer who told me about a setting in Pro Tools, where you can mark the fader so that if someone( (a musician) comes and moves it out of the posistion you had it in... You can see where it was and easily get it back to that place... Can anyone tell me what setting this is? I can't seem to recreate what he did and its driving me nuts! Thanks
Old 09-12-2008, 09:45 AM
guitarmongoose guitarmongoose is offline
Default Re: Color Coding
Well in the mix window there are tiny up and down arrows near the bottom of the channel strip that indicate when the fader is above or below the previously written automation level. I'm not sure if that is what you are talking about.
Brad Semenoff
Sound Editor
Old 09-12-2008, 09:52 AM
Its more of a color option... He would move the fader, and there would be a gray background over the color that the channel strip was... indicating where the fader used to be... It almost looked like there was something seriously wrong with our pro tools rig... but i found out that it was a preference when I asked him about it... He just didn't show me the setting that it was... and I have to know. Its an awesome trick to play on musicians... it doesn't screw up your mix, and it makes the musician think that they're actually doing something.
Old 09-12-2008, 10:10 PM
Scott Goldberg Scott Goldberg is offline
If you record something and then automate it. As long as the READ button is on, the fader will always go back to the written automation. If you are not sure of what you want to write for automation, then touch/latch is what you want to do. It will leave the previous line for you to see as you try to write a better pass at the automation. Even that will snap back once you take it off auto and put it in read mode.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Color-coding... GW Artist Series 1 04-24-2011 11:30 PM
Color coding GS-DK Pro Tools TDM Systems (Mac) 1 06-18-2010 09:13 PM
LE v7.4-Color Palette & Track Color Coding Vbhalla Tips & Tricks 4 01-02-2008 04:13 PM
Color Coding Defekt Tips & Tricks 5 08-05-2007 08:47 PM
Color coding bug in 6.9??? Ian Bodzasi Pro Tools TDM Systems (Mac) 2 05-20-2005 09:51 AM
