Old 02-02-2023, 04:54 PM
Stylin' Audio Stylin' Audio is offline
Default D-Command with Xmon in a HUI world question
Quick question - If I end up having to go the HUI/Neyrinck route, will D-Command still control the Xmon as it does now?
Colin Van Hattem
Noizemaker Productions
Old 02-02-2023, 07:54 PM
LDS LDS is offline
Default Re: D-Command with Xmon in a HUI world question
Yep. The Xmon is controlled via its own dedicated DB15 cable using Midi over RS422. It is totally separate from the ethernet based control of the rest of the desk, and keeps working even when your DAW computer is switched off.
Old 02-03-2023, 04:43 AM
Excellent, that is good news and confirms my assumptions. Cheers
Colin Van Hattem
Old 02-28-2023, 04:42 PM
Kuleone Kuleone is offline
Hi, I'm a little confused also. I have a D-Command and a the newer X-MON, I have the DB15 cable connected between the units. Do I need to get the USB to MIDI cable? How do I add the Eucon software to the setup? Does the Eucon communicate thru ethernet to both units?
I want to go the V-Pro route. Thank you in advance for any help.
Old 03-03-2023, 03:24 PM
LDS LDS is offline
There is no Eucon compatibility in these setups. Only the newer S-series control surfaces use it.
The D Command communicates with the Xmon directly via the DB15 cable. The D command communicates with your computer via Ethernet. The V-Pro app converts the Digidesign Ethernet protocol to midi/Hui.
FS D-Command ES 24 With XMON in ZA StefB Buy & Sell 0 02-03-2021 11:10 AM
XMON not seen by D-command Boe Larsen ICON & C|24 2 10-16-2020 10:32 AM
D Command ES Main + XMON Southsidemusic Buy & Sell 2 01-26-2018 03:07 AM
D Command, PT 9, XMON, 002 puffin ICON & C|24 2 12-20-2010 01:38 PM
Monitoring Cue Mix Through D-Command/XMon? SimonInAustralia ICON & C|24 9 03-02-2009 06:06 PM
