What will NOT work with LE rig in Post production.
Hi
I want to do some work for a post production company and have a LE rig. Mbox 2 Pro and a G5 2x2GHz computer. Is there some limits that I have to have in mind or is it just Go and I´ll be fine ? I need to ge44t the DV toolkit in order for Frame grid and stuff so that I will get... I want to playback the movies on a big TV instead of a small QT movie in protools. Do I need something like VTR or a bonzai drive to make that better !?!? is there anything else that I can´t do what for an example Nuendo can do !?!? My boss wanted me to use their Nuendo rig but I hate Nuendo and would much rather use my PTLE setup.... Any comment on this would be helpful for me THANKS |
Re: What will NOT work with LE rig in Post production.
If they want Nuendo, use Nuendo. If they use PT's, use PT's. There's no easier way to work yourself out of more gigs than being picky about what you use. Especially if they'll want sessions to be opened later by someone else. Do your sessions have to end up in Neundo eventually? If so, I would not suggest transferring from PT's to Nuendo, as now, all your stereo files will end up in spearet tracks in Nuendo. And if you're asking about what you can't do in PT's what you van do in Nuendo, I even suggest more strongly you stick witht he platform your boss wants you to use. If there are ANY problems down the road, guess who's goign to get blamed. And as much as I might complain on forums, I NEVER complain about what gear I have to use at work. |
surround stuff and can't get an HD system, Nuendo is not a bad choice. .. wear nose plugs ... jeff |
yeah maybe you are right. My boss didn´t say he really wanted me to usw Nuendo, but thought that would be easier.... He would have nothing against me bringing my PTLE rig...
Surround I can always do in nuendo even if that will not happen any time soon. So is there something I need to think about useing PTLE ??? |
PT LE - Make sure you follow all of the optimizations for your given system. A smooth running LE system running DV Toolkit should provide you quite a bit of horsepower, especially when editing. You will have to use workarounds to do surround mixing and you'll have to find the best way to organize your stems if you are doing larger projects that exceed the track limits of DV Toolkit.
Nuendo - If you are buying it outright, it's rather expensive. I own it and will use it for surround projects and things I can't do in LE. But at $2000, you have to be committed to using it. If money is not a problem, then you will have the best of both worlds. You can use your Mbox Pro wuth Nuendo via ASIO and that means 1 interface for both programs. If you get a VST to RTAS converter you can run tons of plugins on both workstations. I would agree that going between the programs is not easy. There are some differences in the way they handle files and metadata. So, if you are going to do a lot of going back and forth, you'll need to explore some of the apps meant to handle this kind of translation. Steve |
OK, my boss said that it was ok for me to use my PTLE rig...
So my question is now. I will need to get the DV toolkit 2 and something to sync and play movies on the Plasma TV in the studio. I was thinking about a Bonsaidrive from Rosendahl... does anybody have anythoughts on this ?? As I understand it with the bonsaidrive I just need to send some MTC from PT and the Drive sends the right signal to the Plasma and in sync :-P For me right now it sounds like the ultimate setup for me. But is it something I oversee here !?!? I will not to 5.1, but I have to be able to work with a movie and without sync problems on an extern monitor/plasma.... thanks |
You can conpensate for latent screens with the BD´s dynamic play-back offset. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
BTW,what kind of postproduction stuff will you be doing? Will 32 tracks be enough? |
Post-Production Work Flow | morrison.ece05 | VENUE Live Sound Systems | 4 | 12-22-2011 06:59 AM |
post production | uzi B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-28-2011 11:15 AM |
Post Production Get-together During AES OCT 8 | georgia | Post - Surround - Video | 38 | 11-30-2005 09:15 AM |
002 for post production | CMcBride | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-30-2002 09:48 PM |
5.3.1 post-production work | sherry A | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2002 07:44 PM |
