Re: Using the Digi/AIR plugins live
What I would consider standalone are IK Sampletank, which work inside and outside of the DAW.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
I guess I didn't make myself too clear. I just meant, I'm able to open up Reason and it isn't dependent on having some type of hardware connectiong. For example, PT you have to have a Digi/M-Audio interface connected for it to even run. With Reason I am going to have multiple instances of it opened and each one will be a different rack for each song. I will have a custom setup in each rack that suits the song. I can then just switch back and forth between the racks I want to use. I will probably pick up a smaller converter for line outs from Reason. You are right, you cannot open up Thor and just use it, you have to open up Reason. It would be cool though if you could just open up different instruments in stand-alone mode from Reason. I must also tell you that I am very new to the idea of using this type of setup live. I think it is the future, although, you were doing it way back when. Very cool. Did you see the Navarro video of him using Eleven? He talks about using Eleven live. I would be really curious as to how you would exactly perform using a guitar setup. Interesting idea.
Don't be a puppet on strings! |
I'd have no problem trusting my M-Powered rig live. Just bring along my 1814, run it re-amped into my amp, or give the feed to the sound guy and rock it.
If you have a session created with only your VI's loaded on each track... I mean, how many are you going to use, 3 or 4? I've never had Pro Tools glitch on me when I was just playing a VI for fun or writing purposes. Much greater chance of breaking a string then you are crashing. And even so, if your computer is in decent operating condition, you should be able to reboot at least as fast as a guitarist can change a string.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4 Last edited by SixChurchStreet; 01-09-2009 at 07:10 AM. Reason: typos |
My 'problem' is that I do press play in my performances, specifically within Reason to run a few of my combinator patches. If there was a way of doing this without starting the transport in Protools, I may be able to give Protools LE live a go
Breaking guitar strings does happen, but it's a bit easier to have a spare guitar or two than it is for me to have a second keyboard rig ;-) badseed |
I've seen Reason by itself used live on stage with no issues. |
If You kept it at a cpu minimum it would work but im with you there. LE works great for the stuff i do but in a live situation id worry too much. A small HD system would work great though
For live situtiations I use Ableton Live, never crashed, can rewire reason, can do everything u do with Transfuser (I own it) but the scratch. U don't need external HD's or configure your computer in a particular way.
Good point though I wouldn't like either to happen!
Thanks Si. |
Digi Plugins and Digi Audiosuite plugins not appearing | mattrixx | Pro Tools 9 | 3 | 11-22-2010 05:29 AM |
Live Lite 7 for Digi not re-scanning plugins | Gothboy | Virtual Instruments | 0 | 09-21-2009 09:10 AM |
digi goes into live-market with live console?? | gregor rasek | Pro Tools TDM Systems (Win) | 0 | 07-14-2004 03:02 AM |
What plugins can I not live without... | mamacita | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 08-24-2003 11:00 AM |
using plugins live without opening PT? | steve mcconnell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-04-2003 06:18 AM |
