System crashes and error message -6088
I have been using the Mbox 2 mini for about a year, but just upgraded to the 003 rack. My computer didn't have firewire so i bought an express card that gave me firewire and hooked it all up. I'm running Protools 8 on a Gateway PC with a 500gHD and 4g of ram.
Now while I'm trying to run my new EZdrummer program i keep getting an error message. it says something about holding off interrupts for too long and to increase the buffer size, its error message -6088, but i have increased and adjusted every setting i know to and it still aint workin. Also my computer will crash and dump system memory every now and again. Today it crashed 3 times in an hour. The program will only run for a couple of minutes or so before shutting down. or crashing. But the error message only appears after we have drug the loops from EZdrummer into protools. I'm not the best computer mind either so explaining how to fix this problem to me like im a 5 year old will in no way hurt my feelings. I would really apprieciate the help. Here are the specs Gateway MD7818U - Core 2 Duo T6400 2 GHz running windows 7 home addition 64bit A Dynex 800 port firewire express card with a 800 to 400 firewire cable aprox 4ft long With a digidesign 003 rack using the software that came with the Mbox 2 mini wich was ProTools LE 8.0 but done the update to the 8.0.1 when protools prompted me to. Running 4GB of RAM Im recording to the standard 500GB hard drive. |
Re: System crashes and error message -6088
As already requested in your other thread, we need the specific information that is requested in the "Help us help you" post.
I will copy the instructions here for you: Quote:
Please follow those instructions: it will make it immensely easier to help you. At first glance, I'm betting your firewire card is incompatible, but until we have that specific information, it's just a guess. Also, You need to have 8.0.4 installed to be using W7 64.
It won't let me copy and paste from Sandra. Anything else i can do?
If you are having copy/paste problems, then you may have bigger general computer issues to solve.
When you say "It won't let me copy" exactly what happens?
I run the computer overview in the program i downloaded and when it comes up it doesn't give me the option to copy. It just has everything listed. It will highlight it, and if you double click certian specs it takes you to description of what it is. ie i double click on the processer and it tells me what the processer does with a link to wickopedia.
After the sandra program shows you the results, with the results window still open, press ctrl+c (the standard windows "copy to clipboard" hotkey) or click on the second button from the left on the bottom of the program ("Copy to clipboard").
ctrl + v to paste here.
SiSoftware Sandra
Computer Model : Gateway MD7818U Workgroup : WORKGROUP Host Name : Justin-PC User : Justin Processor Model : Intel(R) Core(TM)2 Duo CPU T6400 @ 2.00GHz Speed : 2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Duo Mobile Technology Mainboard : Gateway BIOS : Phoenix Technologies LTD 99.06 12/01/2008 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.88GB DDR2 SO-DIMM Chipset Model : Gateway 2000 GM45 Mobile Controller Hub Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 4GB DDR2 SO-DIMM Shared Memory : 128MB Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Hynix (Hyundai) HYMP125S64CP8-Y5 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Hynix (Hyundai) HYMP125S64CP8-Y5 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : Mobile Intel(R) 4 Series Express Chipset Family (10 SM4.0, 128MB DDR2, Integrated Graphics) Graphics Processor Storage Devices WDC WD5000BEVT-22ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 466GB (C:) (D:) Optiarc DVD RW AD-7583S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 6GB (E:) Logical Storage Devices OS (C:) : 228GB (NTFS) @ WDC WD5000BEVT-22ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) DATA (D:) : 228GB (NTFS) @ WDC WD5000BEVT-22ZAT0 (500.1GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) PQSERVICE : 10GB (NTFS) HORSE_SOLDIER (E:) : 6GB (UDF) @ Optiarc DVD RW AD-7583S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Gateway 2000 (ICH9M) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Gateway 2000 (ICH9) HD Audio Controller Audio Codec : Conexant High Definition Audio (HERMOSA) Audio Codec : Conexant 2C06h Serial Port(s) : 1 Disk Controller : Gateway 2000 (ICH9) Mobile SATA AHCI Controller Disk Controller : Gateway 2000 Integrated MMC/SD Controller USB Controller 1 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 2 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 3 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 4 : Gateway 2000 (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 6 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 7 : Gateway 2000 (ICH9) USB Universal Host Controller USB Controller 8 : Gateway 2000 (ICH9) USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Marvell Yukon 88E8057 PCI-E Gigabit Ethernet Controller Wireless Adapter 1 : Intel(R) WiFi Link 5100 AGN (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 65% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 3.3 |
Great! Thank you!
Now it will be much easier to help you. Quote:
John Wayne? Quote:
This absolutely MUST be disabled when using Pro Tools. No exceptions.
And again, to run the 003 on Windows7 64, you need to have 8.0.4 installed. (or at least 8.0.3 and the 8.0.4 beta drivers)
Ok. Now were getting somewhere. And the Mbox was running fine but i had this problem with it too, but not near as much. It would run for hours just fine and then i would get the error message about held off interupts. but do i need to have the 003 hooked up too or just the express card. And yes it is John Wayne, i was watchin it lastnight and haven't takin it out of the cd drive yet.
System crashes error message -6088 | Just06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 08-25-2010 10:48 PM |
PT crashes, upon opening a session..no error message | jaguffain | Pro Tools TDM Systems (Mac) | 9 | 04-25-2010 09:48 PM |
ERROR MESSAGE -6088 (Updated information) | Jim Toscano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-03-2006 08:10 PM |
error message 6088- this one may be different | Hazzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-06-2005 07:36 PM |
PT 6.01 crashes HARD with no error message when dragging midi from the regions list | fathermac101 | Pro Tools TDM Systems (Mac) | 1 | 04-10-2003 04:50 PM |
