Old 11-15-2004, 10:44 AM
Questar Questar is offline
Default 882/20 i/o stuck in -10... how do I change it???
I can't seem to change the 882/20 interface from -10 to +4. I've tried the soft switch in the hardware setup but it remains the same in either setting. Is there a factory reset procedure or does anyone have any suggestions.
thanks
Q
Old 11-15-2004, 12:12 PM
minister's Avatar
minister minister is offline
Default Re: 882/20 i/o stuck in -10... how do I change it???
you know, with the 888's there were jumpers inside the box that you had to move. but a cursory glance at the 882 manual doesn't say anything about that. it just says that you CAN switch them. so, the software switch had no effect? dis you re-launch PT after the switch?
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-15-2004, 12:47 PM
Yes, relaunched after attempting to change the settings. Didn't seem to affect anything--still at -10
Old 11-15-2004, 04:03 PM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
If you have OSX try trashing the DigiSetup.OSX file (DigiSetup for OS 9) and restarting Pro Tools.
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Why is my fader stuck and I cant get it to change the volume in the mix? RuffinMedia macOS 5 02-22-2012 02:22 AM
Tempo change causing midi volume to change plugin output tgrfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-05-2011 01:08 PM
why is my fader stuck and i cant get it to change the volume in the mix? Jahlal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-06-2010 06:58 PM
Loop tracks stuck together - change 1 change all jrwallace Pro Tools M-Powered (Mac) 1 02-22-2010 09:19 PM
