Upgrading my home studio
Here are my current recording studio specs:
COMPUTER: AMD Athlon XP 1.9ghz Processor 768MB Ram 300GB Hard Drive M-Audio Delta 66 Soundcard SPEAKERS: Alesis M1 Active Powered Monitors MIXER: Behringer Eurotrack MX1804X PROGRAMS: Acid Pro 5.0 (for recording) FL Studio 6 (for click tracks and such before getting the live drums recorded) Now then.... Over the past year of using this setup, some things have bothered me to the point of needing to upgrade. First of all, I get alot of pops and clicks in my audio. I've extensivly looked into this problem and have figured out to aleviate it mostly, but it's still there. Then there is the fact that distorted guitar once recorded, sounds muddy and just... bad. I've attributed this to my mixer, as anyone I talk to about it tells me that it's complete crap... and that I also need a better program. So I'm looking to purchase a better program and a better mixer. I've had my eye on pro tools for a while. I've been trying to read as much as I can about it, but I'd like to get some feedback here before making my decision. I use Fruity Loops for click tracks and basic drums before getting the live drums recorded, and I hear you can't use that with Pro Tools? I hear that Pro Tools is very limiting in what other companies' programs you can use with it. Is this true? I know there are other options (I do own a PC though, not a MAC) and honestly... I don't really know much about any of my options. I know that alot of the musicians I look up to use Pro Tools, and that's about it. I'm not even 100% fluent in Acid Pro... which for some reason, feels limiting to me... even though I don't know what I'm doing sometimes. Regardless, I've managed really well... as I run the home studio for my band and we've recorded some good quality stuff with my limitations. Anyway, I'd like to know what the differences are between Acid Pro, Pro Tools, and some of the other options I could look at. Also, I'd like some suggestions on a good 14-16 track mixer. I've been looking at a 14 track Mackie, how are those? Thanks for any help anyone can give me! |
Re: Upgrading my home studio
More info, please.
What alleviated the "clicks and pops"? What is your method for recording distorted guitar? Miked amp? Plugin? Reamp? Modeling box? What guitar are you using? The Behringer gear is much derided, but I've found that the biggest problem with it isn't necessarily the sound, but the build quality. Play a CD through it and what does it sound like to YOU, not the people you've talked to? Pro Tools LE and M-Powered is a little more limited than most of the other major platforms out there. The biggest thing going for it is that you can readily go between a "big" studio and your home studio with a minimum of hassle. Also, knowing the Pro Tools interface can only be helpful as you go forward. Mackie mixers are derided as much as Behringers, but by the next level of gear snobs. They're fine mixers, but you're always going to find somebody who tells you its crap. No matter what the piece of gear is. Why do you need a mixer at all? Can't you just mix "in the box"? And finally, have you researched the basic fundamentals of recording? All that boring stuff will improve your sound a lot more than a new upgrade. Head down to a book store an look at the many books on the subject and read a couple. You'll probably be pleasantly surprised at the results. |
I suggest you download the Protools M-powered demo and see if you like it. There is a link on this page:
http://www.digidesign.com/products/m...sics/index.cfm Protools was designed for studio engineers. If you have experience with tape based recording and analog mixers it might be for you. It does not handle loops like Acid and Ableton Live. I doesn't have the most advanced MIDI features. It is very powerful but it depends on how you prefer to work. You might look into Cubase. Download demos and see what you like. I don't know your mixer so I don't know how good it is but I doubt it is to blame for the muddy guitar. The main issue is how you get from your guitar to the interface as the other guy said. With the Delta 66 you have 4 analog ins and if you get an AD/DA you can have 6. If you want to record your band all at once you will want a mixer with 6 good mic preamps and direct outs on each channel. I have a Mackie 1604 VLZ. Mackie has since moved it's manufacturing to China and they don't seem to be able to maintain the same quality. You can do it all with out a mixer but you will need standalone mic preamps. I use my mixer more for MIDI synths. Any computer you use needs to be optimized for audio. The first thing to check is if the chip set, processor and OS are supported by the software. You need to eliminate any unneeded hardware and background programs/services. This can take a lot of research and time. You need to determine if the clicks are happening in you analog chain or in the computer. You may just need to raise your buffer size. |
My method of recording distorted guitar is to plug my guitar into my http://www.zzounds.com/item--KORAX1500G which is then plugged into a channel in my mixer which is then plugged into my M-Audio Delta 66. When playing, the sound is clear, clean, crunchy.... but when recorded and played back, it sounds very muddy and just... not as clear and clean. I don't understand why this is, but I've talked to some people and I've heard different responces like "your mixer sucks for recording, it's only good for playing... and even at that, it's not very good".... or... "you need to use something like Guitar Rig 2". I tried using Guitar Rig 2, but for some reason... there is latency. No other programs give me latency, but when I pluck a string on my guitar while playing through guitar rig, the sound outputs a little late. Quote:
I have heard of Cubase. What are the differences between that and Pro Tools? Quote:
As stated above in this post, messing with the buffer size is something I tried to do to aleviate the clicks. Thank you both for responding, I look foward to learning more about all of this. |
If the mixer sounds fine with a CD, then it kinda follows that it's something else. With an analog mixer, you have to pay attention to gain stage. In other words, don't clip it in the red on the channel, then turn it lower on the master. Try lowering your levels on whatever buss you are using to get to your sound card. Since you mention latency, I'm assuming you are monitoring the Korg unit direct and not listening to the recorded signal as you record.
As for learning Pro Tools, it's the industry standard. If you go to a "big" studio you'll be able to communicate more effectively if you are familiar with the interface. Also, PTLE and PTMP will more than likely do what you want it to do ie: record your band. If you're doing a lot of techno-dance-synthy-whatever, then there may be more appropriate platforms out there. Also, Mackie mixers are fine. Behringers aren't as bad as people like to say. All I'm saying is that no matter what you get, there's always somebody around who'll tell you it's crap. And then when you spring for the top of the line gear, somebody will tell you that you wasted your money and could have just gotten a Behringer. It's a no win situation if you go by what other people say, so consider their advice, but listen for yourself. Personally, I would get a couple of stereo preamps and go direct in to the card. Why not take the most direct route? I don't have any recommendations for books. I don't know what level your knowledge is at. You need to be objective and decide what you need help with. It sounds like a primer might be a good start just to get the basics down. IMO, you should learn the rules before you start breaking them. When you started playing guitar did you expect to sound like Eddie Van Halen within a month or two? Or were you more realistic about the process? Don't expect to make records that sound like a commercial CDs without a learning curve either. BTW, I got the new Tool CD too and have been listening non-stop for a few days. Good stuff! |
At our roots, we are clasified as rock. Throw in progressive and experamental elements, then add some electronic sounds. That's the best way to describe my band. We're like Tool in that the majority of our music is rock based, but there are "some" electronic elements. We all love industrial and techno styles, and like incorporating that into our music sometimes. From what I read, Pro Tools isn't the best software for midi. I have never worked with midi before, but I'd like to. I don't think I'm as hardcore about midi enough to worry too much about that aspect of Pro Tools at this point. Quote:
I've been reading reviews on Mackie and Behringer models around what I have and it just seems like the overall consensus of cheap behringer mixers is that they don't sound well when using them for recording. I don't know why I'm having the problems I'm having with sound quality, but it would be awsome in my openion if the problem would be as simple as switching out my mixer for a better one. You could be right in that neither brand's mixers are "bad"... but if so.... what is wrong with my recording quality? It's very frustrating. Quote:
I've been recording with my setup for 3-4 years now. When I write something that I like, I open up Fruity Loops and figure out what tempo the song I'm working on is at. I create a simple click track with FL, then open up Acid and set the project to the same tempo as FL. That way if I need to loop something, I can simply move it to the line that I want, and it will loop perfectly. If I add more elements to the song, I simply crop the audio accordingly, and move it to the correct line. It has worked for me so far. I think it would definatly be a good idea to get a book on the basics, because although I've tought my self and have a good understanding of what I'm doing, I'm possitive there are things that I just don't understand. I enjoy the learning curve. It's frustrating and overwhelming at times, so I take it slowly... but I've come this far on my own. Quote:
On another note.... Maybe I can give you an idea of how my recordings sound. Here is a link to my band's myspace page. All the clips on there were recorded through the setup I'm using now. You will notice there is nothing close to metal or harder rock on there. Not because we don't to explore those elements (we really do), but because distorted guitar just doesn't record well for me for some reason. http://www.myspace.com/myopicmecca |
All I can say is that you need to learn all the boring things. There are many books written by world class engineers, why wouldn't you want their advice? Go to the book store. Browse the titles. Read about the authors and what they have done. Buy a book and read it. Also, try some of the magazines. They are in the business of selling gear, but sometimes they have good DIY articles.
Here's an online article to try - http://www.sweetwater.com/expert-cen.../d--12/28/2001 Good luck |
If you are recording at 32Khz that may explain a lot. If the Guitar sounds good in the mixer then something is happening to it in the computer.
You probably have plenty of memory to start on ProTools. I only have 512. Just check your chipset that it is compatible. Is that 300Gb HD your only drive? You would be better off getting a second drive is so. |
Yes, I have 2 hard drives. One that is partitioned, and my 300g. The one that's partitioned has Windows on C: and programs on D: including Acid Pro. That one is a SATA drive, whereas my 300g is a regular hard drive. I keep all my audio files on the 300g, and programs on the D: partition of my SATA drive. |
I have a few un-answered questions in this thread. One of them being... what is the difference in recording between loop based programs like Acid Pro, and Pro Tools? What are the big differences between Pro Tools, and Cubase?
Upgrading to Win-7 pro from Home Prem | DonaldM | Windows | 8 | 12-24-2013 10:24 AM |
OT: Home Owner's Insurance when Studio is at home | Dizzi45Z | Pro Tools TDM Systems (Mac) | 8 | 07-16-2010 03:34 PM |
Recording in real studio, mixing at home w/ Pro Tools, mastering at real studio | scummyjob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-17-2010 03:02 AM |
upgrading home studio w/ Mac Pro (help!) | humstrummer | General Discussion | 1 | 02-25-2009 07:33 AM |
Home Studio or Commercial Studio (HELP!!!) | cityscholar | Tips & Tricks | 3 | 10-29-2004 05:57 AM |
