Old 01-20-2022, 04:17 AM
justinhill justinhill is offline
Default C|24 Analogue levels way out??
I'm integrating the analogue side of my new old C|24 and the first thing I noticed was the control room output seemed lower than I expected, and the headphone output was too low to use for detail editing. This being a bit subjective, I looked instead at the cue input/output, which is line-level.
If I send a sig gen signal from a pair of Pro Tools outputs to the C|24 cue in connection and then return the signal from C|24 cue out to a pair of inputs on Pro Tools, I find a level difference of -16dBFS with the C|24 cue level knob at the 'nominal' 2 o'clock position, and still -10dBFS even with the knob flat out.
I haven't done a similar check with the control room i/o but to my ears the difference is probably the same.
Is this a fault with my C|24 or something endemic to the product? It seems completely weird that there should be such a massive level drop going into the unit and it totally disrupts my plans for how to use the thing.
Justin Mark Hill
https://theotheroperation.com
Apple Mac Pro 6,1 late 2013 2.7Ghz 12-Core Xeon E5, 64GB RAM, D500 Graphics, OSX Monterey 12.7.1/Pro Tools Ultimate 2023.12/Presonus Quantum 4848 Thunderbolt 2/Digidesign C|24/Focusrite ISA430 MkII/SPL GoldMike
Old 01-20-2022, 04:34 AM
Default Re: C|24 Analogue levels way out??
I should have mentioned - I did get Pro Tools to update the C:24 firmware to the most recent version, and I did reset 'analog routes' and 'monitor gains' to default.
I've just checked the studio LS output and it's even lower than the cue output.
Justin Mark Hill
Old 01-20-2022, 05:07 AM
its2loud its2loud is offline
Sounds like your monitor section outputs are trimmed down.
Check out page 65 of the manual
https://cdn-www.avid.com/-/media/avi...uide_41362.pdf
Assuming the levels from your Pro Tools interface are correct. No info was provided from you on that part.
Old 01-20-2022, 05:15 AM
Thanks for your reply. I reset all the trims, in fact I set the whole desk back to factory default. In any case, there is no trim function for cue out...
Justin Mark Hill
Old 01-20-2022, 05:18 AM
And you’re positive that the actual analog signal coming into the C24 is correct levelfrom the interface?
Do you have some way to measure it? Route it back into Pro Tools? -20 going out = -20 going back in
Old 01-20-2022, 05:25 AM
Yes of course I should have made that clear. I've checked my interface on numerous occasions and I'm confident it's working within specs. I know the multicore I'm using to perform the tests is good because I tore it out of a working part of the studio. I know my Pro Tools session is set up right because I can plug the test output straight round to the test input and see unity.
I read the C|24 front to back several times before buying the desk. I did notice it has no specifications for any of the analogue sections. Gawd knows what I'll find when I decide to check out the line mixer and mic pres...
Justin Mark Hill
Old 01-20-2022, 05:33 AM
Sounds like everything I would check. Maybe try doing the reset routing, gain and trim controls again as described on pages 119-120.
I don’t know if the monitor/cue outputs are gained down by factory default. It’s possible there is some gain staging you’ll have to do there but that wouldn’t make much sense to me.
Old 01-20-2022, 05:41 AM
Indeed, and there's the nub of my thread. If some C|24 owner can tell me their cue in/out at least is within shouting distance of unity then I'll know I have a faulty desk. But if people chime in and say 'oh yeah you should expect this' then I'll know I have to work around it.
Justin Mark Hill
Old 01-20-2022, 08:00 AM
Default Re: C|24 Analogue levels way out?? ANSWERED, I think
I've just had a conversation with an Avid-certified repair shop. They feel confident that the monitor board needs replacing. Apparently the op-amps die, and also lubricant used in the IDC ribbon connectors leaks out and damages the PCBs.
They confirmed that everything should be roughly at unity if the thing is working as it should.
An exchange monitor board is £450 including VAT and should fix my problems.
Justin Mark Hill
Old 01-20-2022, 01:22 PM
Sorry to hear that. Probably not something you were hoping to hear but it least it’s a fix.
Tracking Levels and Playback Levels paul_g 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 11-26-2010 05:37 PM
Creating the best mix levels / playback levels universe777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2006 10:49 PM
Broadcast levels vs. Podcast levels... McBoob Post - Surround - Video 0 05-05-2006 08:03 AM
Linking track levels w/ pre-fader bus levels? Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-07-2003 10:36 PM
Best Analogue/Analogue Modeling Synthesizer??? David Fisher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-15-2002 12:30 AM
