Old 08-19-2009, 06:07 PM
crizdee's Avatar
crizdee crizdee is offline
Default drag and drop from desktop conforms to session tempo
Despite having selected "no files" for this preference! certain audio files will still conform to the session tempo and be converted to elastic audio
I have to use import audio dialog. which means i can't drag and drop into certain tracks.
This is a pain when i'm importing all the tracks of an entire mix! i think its come from acid?
Chris
Producer, Engineer,
www.ukmastering.com
Old 08-19-2009, 06:31 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: drag and drop from desktop conforms to session tempo
Wowww Chris... Lots of strange behavior as of late on ur rig hunh.its PC time (U kno we always have to Jive the opposite OS).
But seriously, Never had that prob as I do that all the time because of the workspace & CD import bug... But I don't have Acid so I guess thatz why not?...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-20-2009, 05:51 AM
Scott Goldberg Scott Goldberg is offline
Chris,
Just a guess, but have you tried disabling the little green metronome in the browser window, along with taking PT out of ticks mode? I seem to remember that they have some control over things like that. I'm really just grabbing at straws but if I can't try to help my Brit buddy, then what good am I? Taking PT out of ticks mode, I think, disables elastic audio functions.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 08-20-2009, 06:41 AM
crizdee's Avatar
Yes, the acid files have rex type meta data, so i would expect this normally, but as i have "no audio files" selected to conform! one would think it should just import it and put it on a track without elastic. but alas i have to use import audio and take the long route and have all the audio files come into the session in some random order then have to spend 30 minutes finding where things have been placed
This has caught me out a few times now! import someone's tracks and think... holy smoley that sounds weird
chris
Producer, Engineer,
www.ukmastering.com
Old 08-20-2009, 07:17 AM
chris
Mannn thatz a drag (pun intended)
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 11-04-2009, 02:04 AM
preachers preachers is offline
if by any means, i made a audio file conformed already, how can i revert it to orignal state??
Old 11-04-2009, 02:45 AM
PhilBuckle PhilBuckle is offline
Chris, what Scott said, turn off the little green metronome at the top of the work space.
Catches me out sometimes.
G5 Dual 2.7 OS 10.5.6 HD Accel 2 192+96 I/O
http://philbuckle.com/
Old 11-04-2009, 03:21 AM
crizdee's Avatar
Don't think that effects drag and drop from the desktop!
The problem was the .wav's had acid meta data in them but i didn't know the client had bounced them from Acid pro.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-04-2009, 03:22 AM
crizdee's Avatar
What you can do is consolidate the region and then export in the file menu.
Chris
Producer, Engineer,
www.ukmastering.com
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
Drag and drop tempo prob PT8 LE timos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-01-2011 12:19 AM
Drag and drop loops, tempo problems rqstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-13-2009 04:58 PM
Drag and drop from desktop and sample rate convert! what? crizdee Pro Tools TDM Systems (Mac) 7 04-14-2008 09:59 AM
Drag 'n Drop desktop-player?! Arno Peeters Tips & Tricks 2 05-26-2005 10:02 PM
