Old 11-20-2008, 11:53 AM
Kluson Kluson is offline
Default audio drum loop tempo change
Hi There newbie here again.
I'm doing OK with LE but I can't work out if I can change the tempo of an imported drum loop.
I import the audio drum loop which is at 120 bpm but I would like it at say 135bpm how can I do this
many thanks
Old 11-20-2008, 12:00 PM
spkguitar's Avatar
Default Re: audio drum loop tempo change
The simplest way would be to drag/import them into a 135bpm Pro Tools session. After that, if necessary, use the TCE tool to conform the loop to tempo.
HOWEVER...
There is a lot of information that you/we need to know about the loop in question to answer effectively. Is it just a straight audio loop that has no meta data? Or is it a loop that has been beat-mapped and sliced? What format is it in? ACID? REX?
We not only need to know that to give you correct advice, but you need to know that so that you know what needs to be done in the future.
If the files being changed are ACID/REX files, check out my tutorial: How to use ACID and REX files in Pro Tools.
Old 11-20-2008, 01:07 PM
Hi the files are from beat Monkey.
Sorry to say I am a real newbie at this and don't understand the TCE tool.
I'll have a look at your tutorial though
I'm sure that will help
Many thanks
Old 11-20-2008, 02:13 PM
spkguitar's Avatar
OK, They provide three different types of loop files, all of which are (supposed to be) beat-mapped and sliced.
Which file types did you order from them? Plain .wav files? Those would be probably be ACID files if you are following my tutorial.
It is definitely something that you are going to want to familiarize yourself with, especially if you are working with loops. Information about it can be found in chapter 24 of the Pro Tools Reference Guide.
Old 11-22-2008, 03:09 AM
Many thanks
The Beta monkey loops I have are WAV files.
I tried too follow your tutorial but I can't drag the files in?
Sorry I must be doing something wrong. By the way I couldn't open the photos on your tutorial
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
PT 8 adjust Tempo with drum loop webstereo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-04-2010 12:43 AM
The best and easiest way to change loop tempo within pt7.1 siga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-10-2007 08:18 AM
How to change the tempo of a loop in PT LE? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-30-2006 06:05 AM
Conform drum loop to new tempo? The Eggman Pro Tools TDM Systems (Mac) 19 07-27-2002 06:17 AM
