Old 06-15-2008, 10:53 AM
omoanya omoanya is offline
Default Tempo Mapping after the fact w/ Elastic Audio
I have some multitrack audio sessions that i have sped up slightly with elastic audio - they were not origibally recorded to Ptools click (drummer was playing to his own click). Now I want to do some editing and moving of sections/parts but there is no accurate grid set up -- So i'd like to set that up --- I have two questions
1) if i am happy with the new tempos, what Elastic audio setting should i be using before making a tempo map and doing my section/parts editing ? Rendered, X-form etc ?
2) for the tempo map, should i just use the bpm that elastic audio has listed in the project browser? or would i be better off using tab to transient and mark off every eight bars of the song.
Any suggestions for how to do this better?
Thanks,
OMO
Old 06-15-2008, 02:48 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Default Re: Tempo Mapping after the fact w/ Elastic Audio
Take the click track the drummer recorded to and use beat detective to create a beat map.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 06-15-2008, 03:05 PM
I would , but unfortunately, it wasnt recorded and the drum track is now various loops.
Old 06-15-2008, 03:11 PM
ajv205 ajv205 is offline
I would manually create my beat grid by using tab to transient in 8 bar chunks like you said. Its probably the most straightforward and least technically invasive way to it.
Old 06-15-2008, 04:02 PM
OK, thanks -- What do you think about the elastic audio component -- Say i wanted to change the tempo in the future and have the grid stay accurate in terms of bars and bpms - what state would you leave the elasticized track in to build the tempo map ?
Tempo and Elastic Audio Stopped Working together sirjames Pro Tools 10 1 01-22-2012 09:55 PM
Fragmentation of audio by Elastic Audio HD9 tempo change?? bassybob macOS 0 01-05-2012 03:11 PM
Elastic Audio > drag drop loop > session not mapping to loop tempo 440Hz macOS 3 07-04-2011 07:35 PM
Using Elastic Audio match to tempo without affecting the audio Silvio Pro Tools 9 5 06-21-2011 09:41 PM
Conform to tempo/elastic audio? donbenjy Tips & Tricks 4 03-23-2009 02:53 AM
