#31
Re: RAM & Pro Tools
I've had Activity Monitor running for 30 min watching the swap. Session is about 130 track Stereo mix of a 60min TV program. No swap and green memory pressure. The 5.1 sessions will be interesting to monitor.
Re-Recording Mixer/Sound Designer Sydney Australia ---------------------------------------- OS Monterey ProTools Ultimate 2022.4 Presonus Quantum 4848 Mac Studio M1 10 Core, 64gig RAM Sonnet Echo dual NVMe TB Dock Blackmagic Decklink 3G |
#32
Re: RAM & Pro Tools
Yes, good that you understand it now. If you dig deeper, you do not need to be concerned about "pageouts" (which means stuff written to storage and removed from memory) because nobody cares about the stuff you are not needing. But if the number of "pageins" (copying back to memory) is high you may have a problem with memory capacity.
#33
RAM & Pro Tools
“spinners” so to speak, have a lot going for them they’re not slow at all. a 7200 rpm can tear through the roughest of sessions and still hold it’s own. Your 5.1 boots off of one without mods. ssds fail from continuous read write failures. So if you have a “workhorse” session with a “drive killer” I would prefer to use your so called “slow spinner” to take up the slack rather than lose an expensive ssd to failure. I’ll give you an example of a drive killer. An old sd2 big session with tons of edits. Try putting on your internal, and you have a very expensive fix or replacement on your hands for what could have cost you pennies on the dollar for an external.
spinsong.com Last edited by spinsong; 08-24-2021 at 08:44 AM. |
#34
Re: RAM & Pro Tools
Spinners (7200rpm and up that have latency of 10ms or lower) are good for sessions, but WAY TOO SLOW to compare to memory
#35
RAM & Pro Tools
Spinners are not ram. I was talking drive or computer failure.
Some of these new computers have a hard drive the size of a button soldered to the motherboard and tend to overheat leading to failure as well. Sent from my iPad using Tapatalk
spinsong.com |
#36
Re: RAM & Pro Tools
Spinner is ram when you run out of ram and system starts to swap
#37
Re: RAM & Pro Tools
Any old school tech would be able to tell you a hard drive is not ram it’s a different component. Even on the all on one chip it’s a different sector that tends to fail from continuous read writes. Even ram fails even though it’s a different architecture. Sent from my iPad using Tapatalk
spinsong.com |
#38
Re: RAM & Pro Tools
I am that old skool tech and sometimes oversimplify things. Of course I know only REAL memory is the L1 memory built in the CPU, then there is L2 cache and possibly L3 cache before data even enters RAM, and when you run out of RAM unnecessary things are flushed to system drive whatever slow storage that may be. All in all there are only two options: either keep using slower storage or ef up an error message for out of memory problem.
#39
Re: RAM & Pro Tools
#40
RAM & Pro Tools
What I was referring to was a price perspective. A good spinner would be more economical than a laptop failure. I prefer to run the bread and butter sessions off a spinner because they’re cheaper to replace. So if it’s a big session with lots of edits coming from sd2 translations. I would go with a spinner because they’re cheaper to replace than having your laptop fail from running it internal. Nowadays laptops have a button sized hard drive soldered to the motherboard. If it fails you’re out of luck. Also, I was referring to stock drives.
I would also like to note, magnetism holds a stronger bond. While silicon is more frail and fragile and more bound to break. Another thing that would allow silicone to fail is carbonization. Seldomly spoken of, but a can of soda can do away with most silicone. Sent from my iPad using Tapatalk
spinsong.com Last edited by spinsong; 08-24-2021 at 09:43 AM. |
FS: Pro Tools HD 8 + Pro Tools HD 9 + Pro Tools 9 Bundle iLOK license | Delta Music Belgium | Buy & Sell | 1 | 02-27-2019 03:33 PM |
