Eleven Rack Date Code
I am planning to buy a used eleven rack for backup purposes.
The seller told me there is a date code on the back which say date code 137 Also the selled tells me that this unit is from the newer models without the clock issues and came bundled with the ERXP. Any info on the date code?
Gear: Custom Musikraft EVH Frankenstein / Jackson Adrian Smith San dimas I I V Eleven Rack I I V Infrasonic Blow5 Monitors |
Re: Eleven Rack Date Code
I don't know what the 137 means, but if the unit shipped with the ERXP then it is a newer unit. The clock problem happened on some units that were release long before the ERXP was released IIRC.
As with all things electronic, failures happen, so if there is no warranty you will be on your own if something was to fail.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Does the eleven rack have date code info in the serial number | YYR123 | Eleven Rack | 2 | 09-06-2012 06:32 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
How to read the date code on my C|24 | ampnerd | ICON & C|24 | 0 | 05-21-2012 12:35 PM |
Eleven rack expansion crashes on pc at enter code window | Gatekeeper666 | Eleven Rack | 2 | 10-27-2011 04:29 PM |
Eleven Rack Date Codes | hakea | Eleven Rack | 1 | 05-04-2011 03:04 AM |
