Why won't Core Audio Work
Hi there,
Running PT 8.0 on Leopard 10.5.6. Audio seems fine with Pro tools. When I go to use Itunes or other progarams I want to use my 002R for sound.. When I open iTunes, the music only plays through the computer and not through core audio... Core Audio (i thought) is meant to automatically load when 002R is connected.. is that right? I've had it working on previous systems.. no probs.. Anyway.. Core Audio is not loading... Even if I open Core Audio manually still nothing... If I go to system Prefs>Sound, the 002 is there but not selected... so I select it for Output... still nothing. Something's not right. . What should I do? Cheers |
Re: Why won't Core Audio Work
The most basic question first: when you're selecting the 002 in Sound Prefs, you're definitely selecting it in the "Output" tab, not the "Sound Effects" tab, right?
Yes... I'm setting it for output... No joy... From what
I remember I shouldn't need to do anything... I think core audio is meant to start up automatically if I have the 002 connected. |
anyone??
Sometimes you have to reboot several times for it to work. The only work around I found that worked was reinstalling PT.
Core Audio is just Apple's name for basically the entire audio subsystem, so it "starts" anytime you turn your computer on. I assume you mean that you expect the 002 to be selected as a sound output (and for it to work ) when you connect it. That should indeed happen if it was selected as the output device when you last disconnected it (or turned off the computer). Since it's not working like that, you have a badly installed driver (or a broken driver).
So yes, I'd reinstall Pro Tools, since that's what contains the 002 driver for Core Audio. You should *not* need to install the separate "Core Audio drivers" package if you install Pro Tools. |
The only work around I found that worked was not to use it
Stuart Peck - Music Composer Mac Intel 2.93Ghz 12 core - 64gb RAM - OS 10.12 - PT 12 HD Native - Lynx Aurora 16 - Lynx Aurora 8 - UAD Quad - Logic, VEP 6 _____ Spark moderator & beta test for Arturia |
I installed the complete 10 year suite of Arturia synths today including the brass and although they use the same core audio driver and they were made by the same company, installed from the same box, core audio wouldn't play two of them in the suite! Explain tat one. I had to resort to my internal card.
That's how much of a buggy piece of crap the core audio driver is
Try deleting these files (Mac perspective) on your Hard Drive from your system prefrences
com.apple.audio.audiomidisetup.plist com.apple.midi.xxx.plist empty trash and restart Or Download a handy app called "ProTools Pref and Database helper" |
Here is the reply from DTS to a similar thread:
I finally upgraded to Snow Leopard and 8.0.3 at the same time and CAM finally started working correctly.. There must have been some lingering setting somewhere in my Leopard install that was conflicting.. Also, in reference to the idea of installing the standalone drivers.. DON'T DO IT. If you have PT installed then you do not need the standalone drivers and, in fact, according to DTS "Bad things will happen" if you install the standalone over an install of PT
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
96 & 192 only work in Core Audio and not PT... | gregsmith | macOS | 7 | 07-12-2012 06:56 AM |
003 Core Audio does not work with itunes or firefox | m4ca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-21-2008 10:18 AM |
Pcie core + Core audio + Tiger, does it work? | fantomaz | Pro Tools TDM Systems (Mac) | 0 | 12-21-2005 01:04 PM |
Standalone core audio does not work... | PCM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-10-2005 11:39 AM |
Core Audio 1.2 Reason 2.5, Live! don't work! | donmr123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 05-16-2003 02:47 AM |
