I recently upgraded to Pro Tools 8 HD with OS 10.5.5 (from Digidesign linked combo update)
I couldn't get Pro tools to open. I uninstalled it, re-installed and it opened once. I tried to run Reason and was told that Pro Tools couldn't find the reason folder and it said something about checking rewire. The next time I opened Pro tools it wouldn't launch again, and I was able to see that it was stopping and hanging up on the digirewire plug-in as it loaded, then it would give me the "Pro Tools Application has Unexpectedly quit" window. I took the digi rewire plug-in out of the plug-in folder and put it into the unused plug-ins folder. Pro Tools opened right up, however this leaves me no way to run Reason. Anyone have any ideas? Is there another Rewire plug-in I can stick in there? Is this rewire 2 that is being used in ProTools 8? Thanks, (Im running a 2 x 3 ghz Dual core Intel Mac Pro, Os 10.5.5, Reason 4.01, Stylus RMX, Reaktor 5... everything seems up to date including PACE stuff for ilok) |
Odd, isn't it? That's been the case on my home system for the past three PT upgrades. I have to remove the rewire plugin, otherwise it crashes opening PT at that exact spot.
same here, after upgrading to 8.0 PT "quits unexpected" at startup. as drdolla80 told, only moving the rewire plug out of the plugs folder prevents from crashing...
MP 5,1 12core 3.46ghz 96GB Catalina PT Ultimate Logic DP VEPro PT10 HD3 Mavericks MacBook Mainstage https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ |
Same problem here ...
Seems that alot of other people have this issue too. Would be nice if Digi made a statement about this. (Sorry if they did that, but then i haven't seen / found it) Not very elegant to have to drop the digi rewire plugin out for Protools to work.
Rob van Hees |
You need to update Reason, Melodyne, and/or both. It's a known issue with ReWire. If you don't use rewire, just dump the digi rewire plug.
![]() Quote:
Thank you folks for your help,
I found that just uninstalling Melodyne uno Essential, which was the outdated version for use with Pro Tools 7 allowed digirewire to do its job. To uninstall Melodyne I used the app delete program found here: reggie.ashworth.googlepages.com/appdelete I can now run Reason, even though I get strange messages from Reason telling me to check the Rewire Host. I must say that the performance seems a bit sluggish so far though. What worked without hiccup on 7.4 is now too much for the CPU to handle. Time to search the threads for answers to this problem |
the solution (at least) on my config was not only to update all rewire apps, in addition I had to remove rewire extensions from apps, which aren´t still in use anymore
I have the newest version of melodyne studio installed, but 2 years ago or so I installed melodyne essential, which I removed from disk as I bought melodyne studio. But the rewire extension had still remained on disk and this was the problem. the same with Logic Studio, which also crashed on startup.
Digirewire not in plug ins list | patswope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-27-2011 07:00 PM |
Missing DigiRewire.dmp from Plug-Ins | stcowboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-13-2009 07:06 AM |
7.4.2 locks up with DigiReWire.dpm in Plug-ins Folder | PTrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-25-2008 06:26 AM |
Unable to see DigiReWire plug-in | SwirlyKing | Pro Tools M-Powered (Mac) | 4 | 12-03-2007 10:58 AM |
Plug-in library only allowing |
francis eyre | Pro Tools TDM Systems (Mac) | 2 | 08-02-2007 11:51 AM |
