Old 05-13-2002, 10:19 AM
Slideman Slideman is offline
Default Spacebar crash
Seems that the only crashes I get are when I stop playback (or record) with the spacebar (once or twice a day). Looks like a USB issue but I don't know why. Otherwise PT runs like a charm. Any thoughts?
Mix+ PT.5.1.1
G4 400
OS 9.04
Atto
Cheetahs
HD3 accel PT 6.9.2
OSX 10.4.1
G5 dual 2.0
3gig ram
Old 05-13-2002, 02:10 PM
SoundWrangler SoundWrangler is offline
Default Re: Spacebar crash
You might try a Mac OS 9.1 upgrade from 9.04. It's a painless process, no downside for PT & audio in general. FWIW, Apple's descrip. of this update from 9.0.4 says "For the most part, Mac OS 9.1 is a system update that fixes bugs & improves operational performance and stability."
(There's an OS 9.2.x update also avail. on Apple's site. I note in the Digi Compat section that OS 9.2 requires v. 2.7 update of Atto Express.) While at Apple.com, of course, you might snoop whether there's any firmware upgrades, etc. relating to your CPU model, since it's an earlier one. I'm assuming, of course, that you've already combed over your system with Norton Disk Doctor & Anti-Virus, & that obvious system stuff...
Old 05-13-2002, 04:59 PM
Thanks Soundwrangler-Yep, checked all of the normal stuff including the USB connections. I think it might be an extensions problem that has to do with USB (I've even disable the Superdisk USB extension and it still happens).
HD3 accel PT 6.9.2
OSX 10.4.1
G5 dual 2.0
3gig ram
Old 05-13-2002, 08:36 PM
lionel wong lionel wong is offline
hi is it a crash or a hang? i experanced some 5 to 9 min hangs.... simply cos the audio/os (same drive) internal IDE HDD was not defraged for 6 months.
you might want to look into defraging your drive if you have not done it. otherwise, it could be as the others described.
LW.
Spacebar Problem def3mno62 Pro Tools 11 3 02-12-2014 12:47 PM
Can't hit the spacebar without a pop at the end spviii macOS 12 10-15-2012 05:15 PM
spacebar doesn't always work (again) Bennie Cook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-14-2008 02:59 AM
Timeline and spacebar shacke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-18-2007 05:24 PM
Possible fix for not playing from spacebar Greg B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-16-2006 10:23 AM
