Old 08-16-2008, 07:12 AM
ev33 ev33 is offline
Default Playlist Keyboard Shortcut in PT7.4 HD OSX
Does anyone know if there is a keyboard short cut for advancing through playlists on a track? I have not been able to find one in the documentation. Having to select a playlist every time with the mouse when comping vocals is really slow and clumsy. If the shortcut doesn't exist it definitely should!!
Thanks
Eric
Old 08-16-2008, 07:37 AM
clusterer clusterer is offline
Default
it should but it doesn´t.
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 08-16-2008, 09:36 AM
Drew Mazurek's Avatar
Default
Just buy an ICON, they have it!!
www.drewmazurek.com
Old 08-16-2008, 09:43 AM
Kenny Gioia Kenny Gioia is offline
Default
Yes. One of the sillier omissions.
I can toggle thru parameters, track height, grid value and nudge value but not playlists?
Nutty.
Old 08-16-2008, 11:17 AM
Scott Goldberg Scott Goldberg is offline
Default
Thy region grouping all of you comped tracks. Then see if you can opt+click at the lower left of the playlist and the others may pop up like when you are loop recording and you want to pick a track or playlist, hopefully, they will pop up the same way. You muht have to un group the playlists. I don't know if this will work but it may be worth a thy.Hope this works.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Keyboard Shortcut for Playlist switching DiAngelo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-02-2018 07:48 AM
Next/previous playlist keyboard shortcut matthias.matthias Pro Tools 10 0 07-18-2012 03:28 AM
New playlist shortcut? jdutaillis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-20-2009 10:22 PM
Toggle Playlist keyboard shortcut?? hmacdonald 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2006 07:13 PM
Shortcut for "New playlist" FrauMitBart Pro Tools TDM Systems (Mac) 1 04-01-2005 12:57 AM
