Please recommend a setup for me
I want to record midi into PTLE 6.0. I have an Mbox with monitors and I just got a Roland JV-1010 module. I also have a Motu Fastlane 2x2 interface and a Midiman Keyboard controller with midi out only. How can I set these things up so I can hear what I am recording as I record and then at playback?
Jeff K |
Re: Please recommend a setup for me
Assuming you have the midi interface correctly set up and the software for the interface installed, take the midi out of the keyboard into one of the midi ins (Port 1 midi in for example) on the interface. Then connect the midi out of the interface to the midi in of your Roland JV-1010 module. Connect the audio outs of the JV-1010 to the Mbox and set up a track in the mix window of PTLE to monitor the same inputs of the Mbox. Create a midi track and record something to see if if works as is.
It really should be that simple. You may have to change some setting on the keyboard and in PTLE too. Post back if you have any other problems. Hope this helps. [img]images/icons/smile.gif[/img] |
Thanks for the reply. That setup works well. Now, if could only figure out how to consistently control the patches of the JV-1010 from the keyboard. The CC messages are not easy for me to grasp. Are there any good resources for help?
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
5.1 or 6.4? Which one would you recommend? | kurt | Digidesign Hardware & Software | 9 | 12-27-2010 04:03 PM |
Recommend new comp setup? | mattytron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-03-2008 07:53 AM |
OT: recommend a small PA setup for band practice | Matt Whritenour | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-03-2005 05:12 PM |
"Edit MIDI Setup" Setup Menu Item is Missing! | altemir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-08-2004 12:24 PM |
