Quick question. If your tracks and auxes are in stereo but your Master Track is in mono can you still end up with a stereo file? (No bus processing on the Master).
What do you mean by "Master Track"? A mono Master Fader? or a mono audio track? A mono master fader will only control the level of a mono signal and a mono audio track will only record a mono signal. If you bounce either of those as a stereo mix, you will have a stereo file, though it will have the same signal on both channels so will essentially be a mono mix.
Help Us Help You ______________________________________ Chris Pro Tools 2024.10.1 MOTU 24Ao Focusrite LS56 UAD Apollo 4X Heritage Edition Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Master Faders control a path. The don't change the format. If the path is mono the signal will be summed to mono.
Are you trying to end up with a 2 channel dual mono file?
~Will |
No, I'm an instructor and I have a student project that has a bounced wave that is very obviously is stereo but his Master Fader is mono. I guess I'm asking if this Master is controlling any of the stereo channels in his mix.
Ok, I guess I just answered my own question. I faded his Master and only the left side of the mix faded.
What exactly was the bounce source? If you bounce a mono output/master fader you get a mono bounce. I you bounce a stereo output/master fader you can get a stereo bounce (assuming it's being fed a stereo signal), if you bounce using a bus source you get whatever the bus is. ... the importance of understanding how bounce source works. Something to make sure to point out to students... in the simplest case a not uncommon cause of bouncing nothing but silence.
That sounds like a Master controlling a subpath. Have them create a new one with the stereo path and copy whatever settings are on the mono one.
~Will |
Merge two mono tracks to one mono track? | Peters86 | Pro Tools 12 | 22 | 09-25-2016 09:41 PM |
making mono track into stereo or double mono in PT7LE | VeganMuso | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-02-2012 05:36 AM |
mono master | keenast | Tips & Tricks | 2 | 04-13-2011 11:54 PM |
Mono Master I/O setup | Dean Smith | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-22-2009 06:58 PM |
Recording 2 mono tracks to a mono track | MaLa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-02-2005 10:01 AM |
