Old 02-13-2025, 03:31 AM
anuj anuj is offline
Default Frame Rate Conversion Phase issues
I have been using the TimeFactory2 for frame rate conversion. One issue I am facing is that the Printmasters I convert are not phase aligned properly. There is no phase issues internally between the channels of a single track but there are issues between Atmos, 5.1 and Stereo Tracks.
I have attached a screenshot of the 25fps Printmasters, and TF2 settings I use for reference
First one is a 10ch PM, second is a 5.1 PM and third is a ST PM.
Is this normal or something I should be worried about?
Anuj Khajanchi
http://imdb.com/name/nm13287552/
Old 02-13-2025, 04:59 AM
minister's Avatar
minister minister is offline
Default Re: Frame Rate Conversion Phase issues
Hello,
For frame rate conversion, I find it best to use the Sample Rate Conversion trick go from 24-->25 and not try to do it all in one fell swoop in TFII. If you don't know, it is pretty simple. Save a session with just your Printmasters and Stems at the native frame rate, in this case, 24 fps. Then create a new session (same start time) at 25 fps. Session Data Import the Printmaster & Stem tracks as new and (at the bottom left) apply SRC. In the Source, select the source as 50,000 or, (Film to PAL), Dest SR is 48, and use Tweakhead. That is the most accurate way to convert frame rates.
Then in TFII do the pitch correction. I find that doing it on the stem level only, then combining that in the mix at 25 FPS yields the most transparent results.
I realize it is a 2-step process, but, that so far as I know is best. THe SRC happens pretty quickly.
Tom
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 02-15-2025, 11:42 AM
Branko's Avatar
Branko Branko is offline
TimeFactory II will keep the phase for interleaved files only. So, if you want everything to be in perfect phase, select all the channels you want to process, right-click, and apply "select and convert selected files".
That will create one interleaved file, which should be processed then. After it/s done, in the "result" window, export the processed file into separate channels again. The channel order will be exactly the same as it was prior to joining them.
Hope this helps.
p.s. make sure to chose a file format that allows for bigger file size (.wav has a limit of 4GB!)
Branko Neskov c.a.s.
www.loudness-films.pt
Old 02-17-2025, 07:10 AM
Originally Posted by minister View Post
Hello,
Tom
Hey, thanks for the reply. Yeah it is a 2 step process. Bouncing stems after every QC round would be a pain so we keep all the sessions in native frame rate (24 in this case) till the last stage and convert only the required deliverables.
Anuj Khajanchi
Old 02-17-2025, 07:12 AM
Hope this helps.
Hey, this worked. Thanks for the help.
Anuj Khajanchi
HTML code is On
Frame Rate Conversion for video file in Pro Tools RuffinMedia Post - Surround - Video 5 01-20-2016 04:05 AM
audio frame rate conversion nardo macOS 2 08-16-2012 02:47 PM
Help with frame rate conversion Basslab Post - Surround - Video 5 09-02-2009 07:50 AM
frame rate conversion (24>25 & 25>24fps) in Pitch 'n time Studio Studio Pro Tools TDM Systems (Mac) 0 01-10-2008 01:44 AM
Quicktime to PT Frame rate conversion problem zoing123 Post - Surround - Video 12 03-05-2006 08:04 AM
