Old 09-06-2012, 01:44 PM
jshiffma jshiffma is offline
Default Memory Locations Affecting Solo status
Hi all,
I have memory locations set up for mixing groups. Dialog tracks are all 1 location, Music another, etc.
The problem I'm running into is the solo status of any tracks changes every time I swap between these memory locations. I want to be able to progressively add solos as I'm mixing each section and this is making it impossible.
Any thoughts? I feel I'm missing something pretty basic here but googling isn't helping.
Thanks!
-Jeff
Old 02-17-2025, 06:03 PM
davcarey davcarey is offline
Default Re: Memory Locations Affecting Solo status
Old post - but having same issue currently. Anyone figure it out?
David
Redondo Beach, CA
2019 MacPro Rack
3.3 GHz 12-Core Intel Xeon W, 240GB Ram
MACOS 11.6.1 Big Sur
PT Ultimate 2021, HDX x2, UAD Octo x2
Old 02-17-2025, 11:37 PM
ZZR1100 ZZR1100 is offline
Sounds like maybe solo status is automated at certain points, so memory location changes would reflect that?
Mac Studio M1 Max 32gb
Pro Tools 2024.10.2
Sonoma 14.7.4
Focusrite Clarett+ 8Pre
Old 02-18-2025, 12:06 AM
You can't automate solo.
Old 02-18-2025, 03:26 AM
Originally Posted by jshiffma View Post
Hi all,
Thanks!
-Jeff
Have you tried trashing prefs? Testing starting with a new empty session?
Do you have any other automation software running?
If that is not it don't have any great idea about what is going on but...
What Solo mode are you in Latch or X-OR?
Do you have Group Enables active on the memory locations?
Do the groups share solo?
No I can't think of any way this causes this interaction but it's just an area of related things I'd be curious about.
Old 02-18-2025, 06:24 AM
Thanks Darryl - all good suggestions. I was thinking it might have something to do with automation, as there is quite a bit running in this particular session. I will work through these today.
Was also reading about the solo functions of the routing folder tracks, as I have a few of those in play also, and they seem to have a mind of their own when it comes to solos.
Appreciate the reply, I’m working through it and will update the thread if/when I sort it out.
David
Redondo Beach, CA
2019 MacPro Rack
How to solo input channel without affecting monitor jandue Pro Tools 10 2 11-02-2013 07:09 AM
Bar Memory Locations LKing Pro Tools TDM Systems (Mac) 3 05-29-2006 09:00 AM
Memory Locations Wee Gee Post - Surround - Video 3 10-07-2002 02:45 PM
Memory Locations Fave Pro Tools TDM Systems (Mac) 2 04-05-2002 05:01 AM
memory locations please clarpark ProControl, Control|24, Command|8 0 11-29-1999 10:18 PM
