Old 10-08-2010, 08:51 PM
Rezzolution Rezzolution is offline
Default MIDI Controller Unresponsive In Pro Tools, Help Please! :(
Hi guys, I have been banging my head against this for a while now so I thoguth I'd just ask the gurus on here if they could help me out. :) I just bought an AKAI MPK49 MIDI Controller, downloaded all the drivers/firmwares, downloaded and installed a Pro Tools preset template for it, and now all of the buttons respond in the controller's software. Also, I set both the MIDI In and Out to everything open, and the AKSI MPK49 selected for both.
But when I open up Pro Tools 8, Create a MIDI and AUX track, insert a virtual instrument plugin into the AUX inserts, set the MIDI track's input to "all", and set the output to the AUX instrument plugin.
I also have went into the MIDI studio setup options and created my instrument, enabled the MIDI beat clock, and enabled the input devices. Also, MIDI thru is enabled.
Next I arm the MIDI track for record, press the keys on my MPK49, and absolutely nothing happens. No notes are triggered on the virtual instrument - nothing. I'm completely out of ideas please help meeeee!!!!!
Pro Tools LE 8.0.5/ M-Box 2 periodically unresponsive derekc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-22-2012 06:39 AM
Using Pro Tools As A MIDI Controller pavkovlr Pro Tools M-Powered (Win) 1 11-14-2011 02:24 PM
Midi connection causing stop command unresponsive losrack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-28-2010 02:12 AM
Using Pro Tools without a midi controller? Simrin MIDI 4 12-21-2008 12:22 PM
Pro Tools Doesn't See MIDI Controller ReverbMerv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-01-2006 03:57 PM
