#31
Re: Mac Studio - Separate Drive?
Thank you for all that, Darryl!
#32
Thanks Darryl. I copied your post for future reference.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
#33
If it's not clear, and as per this page, if your internal drive is broken, you cannot externally boot an Apple Silicon Mac. This is why the 7.1 is still valuable if you want to quickly recover from a hardware failure. Of course, you can buy a couple or three Studios for the same price.
https://bombich.com/blog/2021/05/19/...lving-platform Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
#34
Peripherally relevant: I'm not seeing anything which suggests that TimeMachine backups to an external TB drive are a bad idea. This is what I do, and what others in my company do.
Of course this is to cover us if we lose data on the internal drive, and I understand that if the internal drive is damaged then these external TimeMachine backups won't help us, at least not on that particular machine, not until the internal drive is fixed and able to receive the data from the backup. But, external TimeMachine backups are still acceptable for common Mac Studio backups, yes? |
#35
I did Time Machine backups for years and years and was very happy with them, including some restores to new machines and total restores when things failed with OS upgrades, but discovered that it's almost impossible to copy them from disk to disk.
When I upgrade my backup disks, I usually copy all my files from the old disk to the new disk. So, a full 250GB disk fits easily on a new 1TB disk. etc. But it turns out that I cannot move the contents of my old TM backups to a new disk, which bothers me because old disks break because they are old. (I keep the old one but I also have the same data on a new one). I even purchased two applications that claimed to overcome the difficulties in copying TM backups. Neither worked. So, I gave up with TM and now use CCC and SuperDuper, along with Dropbox and iDrive for cloud backups. YMMV, of course. Dominic
#36
Which is Apple telling you how much they trust SSD reliability. And they are probably right. Recovery is a small volume, does not suffer from any wear, even if you trash the rest of the NAND it may still be readable. And if things really went pair shaped... a failure of the SSD controller would mean a new CPU chip is needed. On most Macs I assume Apple would require a full motherboard replacement for controller and/or NAND failure. On the Studio models I would hope they provide for CPU and/or NAND card swaps.... but not heard any support war stories there yet. |
#37
Mac Mini M1 16 GB OS 12.7.4 PT 2024.3.1 |
#38
Dominic
Separate Studio LS, Cue and Talkback | Smico | ICON & C|24 | 5 | 11-02-2017 06:31 PM |
Separate video hard drive | Gohanto | Post - Surround - Video | 5 | 04-12-2011 10:00 PM |
Separate bounce drive???? | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-31-2009 11:08 PM |
Separate hard drive | deafmute | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 02-28-2004 10:09 AM |
Installing OS X on a separate drive?? | fumanii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-29-2003 01:31 PM |
