I can't find this answer anywhere. Or does .9 not work with 10.14.6 at all?
![]() Quote:
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 1.0.1, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.6 Pro Tools Ultimate 2025.6/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/8020C/7070A 7.1.4 monitoring. |
![]() Quote:
I got caught out as well and am now needing help getting back to the precious version. If anyone can tell me how to do that, I'd appreciate it. |
it works. There is a simple work around. You will find it under ProTools 2023.9 is here ! Just under your post.
2013 Trashcan w/Monterey. 64 gigs of Ram. 2009, 8 Core Mac 5.1, (32 gigs Ram),2012 MacPro w/Monterey. MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.6 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
You can remove the Sketch plugin thereby allowing this version of Pro Tools to run.
To do that,
The first step prevents Pro Tools from putting that plugin back every single time you open Pro Tools. The second step removes the plugin if it is already there.
Pro Tools Ult 2025.6, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 14.7.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
![]() Quote:
Edit: I did go ahead with removing the sketch plugin and although I had tried several times to load it before there was no problem now, so I did not need the second step. Last edited by piedpiper; 09-29-2023 at 01:28 PM. |
Plugin directory is:
System drive > Library > Application Support > Avid > Audio > Plug-Ins
The sketch system plugin needs to be removed from it's stash in the app bundle that is all you need there should not be an copy of this in the normal plugins folder. That was me being dense when I wrote those instructions. I thought i had corrected that, is there a post out there still saying this?
And yes the symptom here is either HEAT.aaxplugin or the Pro Tools Sketch.aaxplugin appearing hung during loading in the splash screen. ... it's Sketch that is the problem regardless of what shows. |
PT 2023.6 & Eucon 2023.6 Work Perfectly Natively, but no connection under Rosetta | theodd | Avid S1, S3, Dock and Control App | 14 | 10-19-2023 07:23 PM |
does 2023.9 work in os10.14.6 if i use the 2023 hd driver? | [email protected] | Pro Tools | 1 | 09-25-2023 09:13 AM |
Eucon 2023.6 Crashes often when using PT 2023.3 | Selle Sellink | Pro Tools | 3 | 08-06-2023 02:29 AM |
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! | off the wall | Pro Tools | 9 | 03-28-2023 10:33 AM |
