Old 08-16-2001, 08:12 PM
MichaelK MichaelK is offline
Default MIDI is suddenly silent silent... possible bug??
Let me preface this by saying that this is NOT the same as the "How do I hear MIDI?" question everyone asks the day they set up. This is a recent development on newly created MIDI tracks only. Old MIDI tracks seem to work fine.
Until recently I've had no trouble with MIDI recording in LE. My OMS studio set up right, the MIDI track is record enabled, a device is selected, my controllers are set up right and sending MIDI properly, my MIDI interface is functioning properly and there's an aux send hooked up for the audio. But when I play the controller while the system is stopped, there is no sound. No MIDI signal indicated on the track's meter, the sound module's "MIDI" light (which indicates MIDI data being sent or received) doesn't light up, and no sound comes out. However, when I click "record," MIDI data is recorded on the track in real time. When play the track back, the sound module plays it and I hear it normally.
So to summarize, for some reason MIDI data is not making its way to the track unless the "tape" is rolling, but while recording the module doesn't play back. The module only sounds during playback, when "record" is not enabled on the track.
Is this a bug in 5.1.1? Or did something perhaps get accidentally reset when I upgraded, like the I/O settings did (another topic entirely)?
-- Michael
PT Ultimate Native 2021.10
Mac Pro 7,1 16-core, 288G RAM
OS 11.6.1 Big Sur
Old 08-16-2001, 11:54 PM
jophoff jophoff is offline
Default Re: MIDI is suddenly silent silent... possible bug??
On the last session I worked on, I had to open OMS Setup every time after launch before I could get any MIDI input to work, but after that it was OK.
Old 08-17-2001, 07:11 AM
Thanks for the suggestion. I've been trying that. I also tried the "test studio" function in OMS setup and everything seems to be working fine there. But when I quit OMS setup I still have the problem.
Anyone else?
-- Michael
OS 11.6.1 Big Sur
Old 08-18-2001, 12:02 AM
maj maj is offline
I'm having the same problem...what midi interface are you using? [img]images/icons/confused.gif[/img]
Old 08-18-2001, 09:34 AM
Nocturnal Nocturnal is offline
Are you using a Midiman interface. I'm using a Midiman Midisport 2/2. My Digi Midi interface has always been fine but my Midisport would only work after I boot the computer once and then restart the computer.
I thought it could be the version of OMS I was using (2.3.8) so I went back to 2.3.7 but that didnt work.
I downloaded new drivers aswell from the Midiman website and now it works fine.
Sooooo - it could be the version of OMS you are using does not work with your interface
or you might need to download the latest drivers from the manufacturers website.
if only Digidesign would develop their own Midi interface with Time stamping like you can get for Cubase and Logic!!! [img]images/icons/wink.gif[/img] [img]images/icons/grin.gif[/img]
Hope this give you something to think about.
Nocturnal
Old 08-19-2001, 10:41 AM
I'm using a MOTU Midi Express XT. It has worked fine since I got the DIGI over a year and a half ago, just until the upgrade to 5.1.1. I don't know for sure if the problem is related to the upgrade, because existing tracks in previous sessions work fine. However, I will check for updated drivers.
-- Michael
OS 11.6.1 Big Sur
Old 08-19-2001, 07:43 PM
Follow-up: The only new "driver" available was a newer version of FreeMidi, which I downloaded and installed. They added a few new patch lists, that's all. No change otherwise.
However, I found that this problem is happening in only one session. I tried adding new MIDI tracks to other sessions and there was no problem.
Time to call Digi, I guess. Sheesh...
[ August 19, 2001: Message edited by: MichaelK ]
-- Michael
OS 11.6.1 Big Sur
Old 08-19-2001, 09:16 PM
I've noticed that sometimes my Input Device preferences are forgotten and that a quick check to the Input Device dialog box and reselecting my master keyboard fixes this occasional glitch. I do use the MIdiMan Midisport 2x2, so I don't know if that's a problem as well.
Old 08-19-2001, 11:08 PM
Kevan Staples Kevan Staples is offline
jophoff has a good suggestion. Check the OMS MIDI input settings from within Protools. It may be that your device is disabled.
Check midi thru in Protools as this would cause the problem you describe as well.
Open OMS Setup and select "OMS Midi Setup and select the pref for "Run Midi in Background" This wouldn't cause you're problem but may help to keep it stable and is by far the best way to run OMS. It controls the ports at all times regardless of which app is being used.
Kevan
MiDi is silent after recording BigL Pro Tools 9 1 05-22-2013 06:55 AM
recorded midi silent steveurwin MIDI 0 09-04-2006 05:15 PM
when protools starts my midi io routings go silent espada3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-02-2005 01:33 PM
Digirack Click silent w/creation of new MIDI track dancoleman Pro Tools TDM Systems (Mac) 10 02-16-2005 08:37 AM
I now have a SILENT G4.... kite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-10-2004 12:50 PM
