Consolidating Sessions with Structure Free
Is there are good way to give a session to someone which includes Structure Free?
Save Copy In... doesn't seem to copy the sample files.
Waves Plugins FOR SALE |
Re: Consolidating Sessions with Structure Free
Parroted by me & Tapasquawk 1
Ok, if you are using a patch that you created, copy it into the session folder via the plugin window commands.
I have a session drive and a sample drive. I have maybe 20 or so sessions where I have used Structure Free simply to load the odd sample here and there and have them triggered by MIDI. I want to give the session drive away including the samples needed to play back the sessions.
You can save it as a monolithic patch file. Right- mouse click on the patch you created in the left patch column and save it into the corresponding session folder.
Is that a Structure or a Structure Free thing?
I see this when I right click on a patch.
Dang! It looks like you can't save in the free one. Well, as long as you make you patch out of audio used in the session, you should be able to transfer the session without a problem.
I have a Structure license I could use just to do the session organising. If I installed Structure (not free) would it open on those channels where I currently have Structure Free and allow me to consolidate all the samples into the session folder?
The copy samples to session folder was only ever supposed to work when the samples being referenced were from an optical disk (CD/DVD). If you use the full version of Structure just save the patch and keep it in the session folder.
Structure Free unable to load homemade files from Structure 1.0 | tuchel | Virtual Instruments | 0 | 04-26-2013 09:10 AM |
iLok problems for structure...reverted to structure free | thisistruth | Pro Tools 9 | 4 | 12-07-2011 08:04 AM |
When I loaded Structure from VIRT pack, Structure Free menu still there. | dl0banter | Virtual Instruments | 2 | 06-12-2011 02:23 AM |
Consolidating Sessions and backup to cloud or other | Ronnisi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-20-2011 01:46 PM |
