Sorry 'bout that. This B&H catalogue just arrived and I was reading in the dark. That box above, Dulce Systems Pro Duo, is eSATA only. Comes with 2x 1 meter eSATA cables (kind've short). You can purchase snap on ferrite beads, telecomms require beads on either end, USB, Firewire, all data carrying wire. www.granite.com www.kimber.com for cables with dual ferrites.
B&H also sells an all aluminum fanless box called dvBOX (PRDVBD) $95 USD -- enclosure only. I would go with the Hitachi everyone recommends. Dismount and power down if unit does not sleep. Also my new OWC unit is plastic and sucks, however it's an Oxford set with firewire 800 & USB-2 which I guess could be useful for back ups just as the unit you posted, but the cool thing is an ide to SATA board for PATA or SATA drives, makes it usefull for old dawgs like me with a ****load of drives. But if you plan to use any PTs le firewire 400 audio interface the hub reverts to 400 just as SCSI did and you will not benefit from the Firewire 800 ports onboard bandwidth wise. Wish their was some word from AVID about eSATA and PTs-9. Unless they are looking at eSATA as SATA. Express 34/54 Cards with eSATA I think about 5 times the bandwidth of Firewire USB-2. |
![]() Quote:
eSATA, in terms of performance and bus type etc, is simply SATA with a different connector designed to be more sturdy for repetitive insertions/removals... Or is that not true?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
http://oyendigital.com/firewire-800-usb-hard-drive.html
If you really want silent then you could go for: http://oyendigital.com/hard-drives/s...SSD-120-M.html MiniPro 120GB External FireWire 800/400, USB Portable Solid State Drive SSD Advantages over standard hard drives Faster seek time - great for HD video editing Rock-solid durability - No moving parts, able to withstand high impact (1500Gs operating shock) Lower power, cooler operation Ultra silent operation
Hack Pro (4.2Ghz i7 Quad/16GB) PT11 / OSX 10.8.5 TC Electronic Konnekt 24D |
![]() Quote:
http://www.dsp-memory.de/v1/catalog/...th=9012_10105& Currently I follow new plan: this enclosure: http://www.dsp-memory.de/v1/catalog/...ucts_id=10830& and this hard drive: http://www.hitachigst.com/internal-d...velstar-z5k320 Probably the quietest mechanical HDD on the planet. Quote:
regards wasserwerk |
Silent external firewire drive? SSD? | Piers Gibbon | macOS | 5 | 02-22-2013 10:01 AM |
Why does Avid recommend external USB over external Firewire for audio drive? | DJ Hellfire | Pro Tools 10 | 10 | 03-29-2012 09:39 PM |
Firewire Solo and Firewire External Drive | TrevorForrest | Pro Tools M-Powered (Win) | 6 | 04-28-2006 02:59 PM |
How can you use an external firewire drive and Digi002 with only 1 firewire port? | CraigD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-16-2003 01:11 AM |
Why is my LaCie external 80 gig, 7200 rpm firewire hard drive an invalid drive to be | Fucius | General Discussion | 4 | 03-19-2002 11:26 PM |
