No authorization code!!
Hello, i have just purchased a Digi 003 with Tools LE8 2nd hand.
Everything is installed. Comes to the first boot of Tools and it asks for an authorization code. Seller says he has supplied everything that came with it new. There is no seperate printed 'setup' guide with the code. Only the install disc. Where can i find this code. thanks. |
Re: No authorization code!!
Also, seller says he has never used this PTools software, only the 003 with Garageband.
Maybe it needs to be registered then the code will be sent out!? |
Hey!
Get in touch with the seller! Even if he used his interface with GB, when he bought his 003, it must have come with everything, including the Setup guide. The Authorization Code is on a sticker pasted at the back of the first page. If he forgot to sent it to you, you can still send him an email to get this Code. It should start with : DIGI0800.... Good luck.
Green Room Studios, France Mac Book Pro i7 15"4 Mac OSX 10.6.6 PT 9.0.2 DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate. PTLE 8.0.4 002R Unit and MBox Mini SSL XLogic Alpha Channel. SPL Goldmike valve Preamp. DBX Analog Compressors, Gate and Eq. Monster Cables Home made & Neutrik Patchbay. Brauner, Shure, Seinnheiser and T.Bone mikes. Tannoy 8D Active monitors. |
Hello, seller says he sent all items included in the purchase.
There is no printed copy of the set up guide. Hopefully he can find it. Is there any other way to get this code? |
Look on the back of the CD cover. There should be a sticker there with the code.
Hello, there is a code number on the back of the cd cover.
Does not start with DIGI0800 though. Would it be worth trying this number? |
Need Authorization Code | DjCooley | Licensing & Accounts | 5 | 09-20-2016 09:49 AM |
authorization code | ronaldb7 | Post - Surround - Video | 0 | 12-02-2008 03:12 AM |
i need help with my pro tools 7le authorization code code | NDepthProductions | Pro Tools M-Powered (Win) | 6 | 03-14-2008 01:30 PM |
Where is my Authorization code ? | Sidhu | Pro Tools M-Powered (Win) | 1 | 11-26-2007 06:49 AM |
Where is the authorization code? | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-31-2004 06:51 PM |
