Old 02-22-2006, 02:51 AM
buckaroo buckaroo is offline
Default Mbox with outboard Compressor
In regards to my other post about the Mbox inserts or ins/outs with a compressor, I wanted to know if the following was possible, as im getting a bit of a headache with this!
I have the following :
PC for VST's only using Chainer (w/Midi interface) - using Mbox 1 as normal ASIO s/card > SP/DIF digital to :
Mac Running Logic & Protools w/ MOTU 828mkII (controlling the PC via Midi, as a VST sound module)
On the PC :
I have a SPDIF connection going from my Mbox into the 828mkII working fine, but can i permanently attach an Alesis 3630 compressor to the Mbox ins/outs and THEN send the compressed sound across via SP/DIF?
I have the 3630 connected to the Mbox ins/outs and the 3630 is registering on the compressor as audio in (meters flashing), but i can't hear any "compressed" signals? what are the correct connections for the mbox>3630? - can this all then be transfered across via SPDIF?
On the Mac:
I have logic running but also wanted another outboard compressor to be heard and "printed" on the Real-time bounce before bringing into PROTOOLS. i have connected this via the 828mkII's 9+10 ins/outs but the logic>helper>i/o doesnt seem to be working right? I have selected the output of the comp, and can hear compressed sound but cant record it?
I would like this on the OUT-1-2 ideally but i believe there is a bug with this? i have tried going to a bus instead but still no joy, OR if i select the compressor on the ins & outs i get a flanged feedback delay!
I think i'm almost there but can anyone tell me the correct settings for both computers so i can set up, & get it to work? Thanks in advance
Connecting outboard compressor to MBox RoxyRiot FireWire & USB Audio Interfaces (Mac) 0 05-01-2013 10:07 AM
Connecting Outboard Compressor to Mbox buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2006 08:47 AM
Mbox inserts with Outboard Compressor? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-16-2006 10:51 AM
Mbox inserts with outboard Compressor? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2006 08:05 AM
Outboard compressor? where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 12-13-2002 06:27 PM
