Old 02-19-2006, 08:47 AM
buckaroo buckaroo is offline
Default Connecting Outboard Compressor to Mbox
Is there a way to connect an outboard compressor to the Mbox permanently?
I know there is inserts on the Mboxm but would like to connect an external Comp so that i can "record" the compression on mixdown (bounce to disk) as part of the mix?
Is this possible?
Also along the same lines, is it possible to connect with inserts/sends, an outboard midi filter so that i can create midi automation by drawing in PT but control the outboard filter? also would this be recorded as a BTD?
Thank you.
Connecting outboard compressor to MBox RoxyRiot FireWire & USB Audio Interfaces (Mac) 0 05-01-2013 10:07 AM
Connecting an outboard compressor to a 003 rack ungratefuldead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-20-2009 03:35 PM
Mbox with outboard Compressor buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-22-2006 02:51 AM
connecting outboard to mbox??? Bob333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 01-12-2006 04:30 AM
connecting an outboard compressor jinglemaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-17-2002 02:10 AM
